Old 02-07-2007, 04:24 PM   #1
Default XXX-T help
Does any one know if someone makes Aluminum and graphite parts for the xxx-T. Thanks
rugdog is offline   Reply With Quote
Old 02-07-2007, 05:04 PM   #2
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
You can get the whole truck in graphite, but Im guessing you want the carbon fiber looking graphite or something, which Ive never seen.
Aluminum, Im not sure as well, but for a racer or basher its not really recommended because it bends so easily.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 02-08-2007, 12:59 AM   #3
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Losi makes full graphite parts for the XXX-T - chassis, shock towers, suspension arms etc. What alumimnium parts are you after? You can get titanium hinge pins and turnbuckles
Cheers
Drift_Buggy is offline   Reply With Quote
Old 02-08-2007, 06:20 AM   #4
The aluminum shock arms and a shock tower.
Old 02-08-2007, 03:04 PM   #5
Why do you want aluminum shock arms? 1/8 buggies don't even use aluminum shock arms
Cheers
Old 02-08-2007, 03:59 PM   #6
LOWGEARED's Avatar
Its not a recommendation to do it But if you like the bling!!!!
http://www.asiatees.com/model.php?br...el=XXX-T&pid=1
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 02-08-2007, 04:45 PM   #7
Bit_Rusty's Avatar
Just search around for MF1 parts... you can get every part of your truck in graphite.
Aluminium not a good idea IMO. Key to these trucks is keeping them light!!!
Bit_Rusty is offline   Reply With Quote
Old 02-08-2007, 05:41 PM   #8
The reason I want aluminum is because I just put a novak 3.5R brushless and I don't know how well teamlosi's grapite parts hold up in hitting a wall or crashing during a race.
Old 02-08-2007, 05:49 PM   #9
Davidka's Avatar
Trader Rating: 77 (100%+)
Nothing will survive hitting the wall at the speeds a 3.5 will make (assuming that you have a track with unlimited traction). You would be best served by getting a 7.5 or 6.5. A 3.5 will not work in offroad, you may not even be able to gear a XXX-t down low enough for one.
Old 02-08-2007, 06:09 PM   #10
Bit_Rusty's Avatar
If you're dead keen on going Captain Insano with the motor.. then might just be best to leave everything as plastic.
Stuff WILL break if you clip objects at that speed. Better off doing a plastic a-arm that costs a few bucks and a few minutes to replace... rather than snapping a chassis or the like...
Old 02-09-2007, 12:03 AM   #11
Send a message via AIM to Brushless Corey
Here are some sites to get your bling on....
www.teamtrinity.com
www.teambluestar.com
www.asiatees.com
www.lunsfordracing.com
Brushless Corey is offline   Reply With Quote
Old 02-09-2007, 12:08 AM   #12
I've upgraded my RTR XXX-T for full graphite since I've owned it. I broke more plastic pieces and that is the main reason I upgraded. I figured since it was broke might as well upgrade.
If I were to add anything aluminum on my XXX-T, it would probably be the front and rear pivot blocks and maybe the rear hubs and front steering buckles. Thing is, you add alot of aluminum and hit something really hard your gonna bend the aluminum and the initial shock of the impact will probably break the plastic or graphite parts connected to it. Might as well break one part rather than replacing a bunch.
Old 02-09-2007, 12:33 AM   #13
Aluminum will just bend!!!! Get graphite! And with that motor you are going to need really, really good tires to get traction. What tires do you plan on using?
Cheers
Old 02-09-2007, 02:31 AM   #14
WheelNut's Avatar
Send a message via MSN to WheelNut
It doesn't matter what tires your running, you will never, ever, ever get enough grip to lay down the power that the 3.5R puts out (isn't it over 475W? ). The only place you could possibly get enough grip would be on carpet, but even then the truck would just wheelie all over the place. Basically in a 2wd truck the only thing the 3.5R will be good for is top speed runs. If you do plan on racing the truck at all (as in on a track) please do yourself a favour and buy a 6.5 turn motor. Not even do the the pros use something as insane as a 3.5 turn motor when racing, most of them use a 10 or 11 turn brushed motor which is roughly equivalent to a 6.5 turn brushless motor.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 02-09-2007, 03:59 AM   #15
X5 Addict's Avatar
Trader Rating: 20 (100%+)
I'll second that, well said.
I have an MF2, I have only replaced the front pivot plate with a Trinity aluminium part as this is a weak point IMO. Other than that, why are you planning on smacking this thing full flight into a wall? A 3.5 will be absolutley insane in a straight line! I run a 5.5 and the front wheels spend more time off the ground than on it!
Bed Head Johnson, head slappin' the Gedlow and soothed with garlic butter....
Peli, should have swapped at 100, that's the real reason the wrist is the way it is... ;)
www.stivesrc.org.au
X5 Addict is offline   Reply With Quote
