Old 02-07-2007, 11:59 AM   #1
Stewart Fan's Avatar
Trader Rating: 18 (100%+)
Default Power Supply?
I am just getting set up in electric racing. I have a few cheaper chargers but have just decided to step up and buy 2 new ICE chargers. Now I need to figure out what I need to get for a power supply. i would like to have something that will run multiple chargers. Any sugestions are greatly appreciated.
CnC Raceway Woodland WA
HOUSTONS ENGINE SERVICE [email protected] (service for novarossi based engines)
Stewart Fan is offline   Reply With Quote
Old 02-07-2007, 12:03 PM   #2
you need a powersupply that pushes at least 14A constant. The SHE is good, and a good price. If you want the big dog, the Rivergate(?)bulldog 30A is supposed to be killer, but it also costs over $200. There are quite a few power supplies in the BST forum here. I would recommend a distribution box, cuts down on connections to the PS, and you can switch different leads off.
HTH
Rod
gatermaxx is offline   Reply With Quote
Old 02-07-2007, 12:14 PM   #3
d4man's Avatar
I use this power supply and can run 3) LRP Pulsars charging at 5 amps each with no problems!
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 02-07-2007, 12:43 PM   #4
Rysuleod's Avatar
This one has been posted a bajillion times on here. So I'll post it again.
Pyramid 20A Power Supply
p.s. I once used it with two chargers at the same time with no problems. I've had mine a few years and I'm happy with it because it was cheap!
Rysuleod is offline   Reply With Quote
Old 02-07-2007, 01:02 PM   #5
d4man's Avatar
Yep, that one will work also!
Thats a better deal than what I listed! Roughly 20 dollars less and 5 more amps!!
Old 02-09-2007, 04:35 AM   #6
X5 Addict's Avatar
Trader Rating: 20 (100%+)
If you're handy with electronics, you can modify a Computer power supply. 450W would give you around 20A @12V and they are regulated. Would cost all of about $30 or so?
Bed Head Johnson, head slappin' the Gedlow and soothed with garlic butter....
Peli, should have swapped at 100, that's the real reason the wrist is the way it is... ;)
www.stivesrc.org.au
X5 Addict is offline   Reply With Quote
Old 02-09-2007, 09:46 AM   #7
Trader Rating: 32 (100%+)
It is best to total up your load in watts and then purchase a ps that is somewhat bigger than the most power you will ever pull.
The absolute max of an ice is 120 watts and with impulse charge is 180 watts
2 of them together at max can probably get away with 250 watts without impulse engaged and with impulse charge engaged you will need about 300 as long as the 2 impulses are not timed together (or lined up)
If you happen to be doing mini batts or radio batts or other small jobs then 100 watts can run a half dozen chargers.
gulio is offline   Reply With Quote
Old 02-09-2007, 10:39 AM   #8
Thanks for all the help guys, I ended up with a 30 amp Bull Dog off the for sale forums right here.
Computer power supply used for charger power supply? 66Racer Radio and Electronics 7 05-25-2008 12:52 AM
RC BLOW OUT !!!! Ice chargers,novak discharger,power supply,power bridge,integy setup shrum1340 R/C Items: For Sale/Trade 20 07-23-2007 05:37 AM
>>> TEAM NOVAK N-POWER POWER SUPPLY GREAT CONDITION $50 <<<< mach51 R/C Items: For Sale/Trade 3 02-06-2007 10:53 PM
turning pc power supply into a rc power supply andy_666 Electric On-Road 20 01-16-2006 05:20 PM
SEC Power Supply vs. Hobbico Power Supply? F1Junkie Electric On-Road 1 06-05-2004 08:52 AM
