Hot Bodies Cyclone D4 EP buggy >
Old 07-21-2008, 02:25 PM
  #751
sliprip's Avatar
Now this I gotta have!
sliprip is offline
Old 07-21-2008, 10:49 PM
  #752
Suspended
Looks like we have a solution to the scoops hitting the battery brace problem. Also what front tires are on the car in that picture? Something else new from the boys over at J Concepts?
ifuonlyknew is offline
Old 07-22-2008, 12:28 AM
  #753
jconcepts barcodes
Chris Jarosz is offline
Old 07-22-2008, 01:38 AM
  #754
agressive1's Avatar
Trader Rating: 15 (100%+)
Yes i agree looks like we wont be having problems with the scoops and the battery holders.
Ok guys,,,,,
I got my car running, D4 of course running a GTB novak 5.5 motor and 5500mah lipo maxamp batterys. Im using a 16t pinion with stock spur.
Now is it just me or is there a problem with my car. I personally dont think these things run hard at all.
My 9t Team Orion brushed motor using intellects 4200mah and Nosram patriot would of easily kept up with this.
Yes it does have smoother power but i didnt see what the big excitement is with brushless.
Mind you it was the batterys first charge.
Any thought guys or is this the way it is?
agressive1 is offline
Old 07-22-2008, 07:23 AM
  #755
scott54's Avatar
You need to gear that baby up! With a 5.5 you need to be up around a 19 or 20 with the stock spur. I was having serious heat issues with mine, and going off the old rule of thumb, I kept gearing down.... but it was making the heat worse and slowing the car down. I finally went up and the car started to rip even more and no more heat problems.
scott54 is offline
Old 07-22-2008, 07:48 AM
  #756
PW
PW's Avatar
Good eye guys!
We actually gave extra room for LiPos in the rear. We also made room in the front for BL speedos with fans
The tires are indeed the new Bar Codes
PW is offline
Old 07-22-2008, 08:36 AM
  #757
DavidAlford's Avatar
Trader Rating: 32 (100%+)
I've been lucky enough to get to test the sample saddle lipo from SMC. I think everyone is going to be very happy with the fit. The pack is a 4900 hard case. It fits with about 4mm clearence from the topdeck. Has plenty of room front to back on the battery mount post. It's wired just like their brick packs. Its going to be the real deal.
DavidAlford is offline
Old 07-22-2008, 11:12 AM
  #758
Suspended
Originally Posted by PW
Good eye guys!
Are you talking about the front tires? Because those fronts look nothing like the Bar Code rears. I was hoping that J Concepts was gonna make Bar Code fronts that have the same tread pattern as the rear. What they need to do is make rears that have the same tread pattern as those fronts to use on "taper pin tracks" I thought the only reason everyone runs the BK Bar rear Taper Pin front combo was because losi didn't make BK Bar fronts. I thought J Concepts was an "outside the box" company? Now, if they did testing and found that front tires with a "Bar Code" pattern just didn't work and the "tapered pin" design did, then I retract my previous statment.
Old 07-22-2008, 07:40 PM
  #759
I don't if someone already give a PDF or a link to a editable setup sheet for this car but here you will find one, with some addional setups.
Hope that can help some of you!
Arn0 is offline
Old 07-23-2008, 03:12 AM
  #760
agressive1's Avatar
Ok will give a 19-20t pinion gear a try.
Old 07-23-2008, 10:00 AM
  #761
scott54's Avatar
I like the new JConcepts body but it doesn't include an undertray.
scott54 is offline
Old 07-23-2008, 11:30 AM
  #762
AndyMoore's Avatar
Trader Rating: 64 (100%+)
Its meant to work with the stock undertray.
AndyMoore is offline
Old 07-23-2008, 11:34 AM
  #763
Suspended
Default AE.......................IS THE KILLER OF ALL! B4 & B44..
Fresh new body needs a new undertray also keep it clean!
losidriver70 is offline
Old 07-24-2008, 07:14 AM
  #764
Here are some pictures of the mount system I setup for the SMC pack in my car. It will give you an idea oh the size. Its close to what Billy did with his Tracpower 3200.
Attached Thumbnails Hot Bodies Cyclone D4 EP buggy-d4-mount.jpg   Hot Bodies Cyclone D4 EP buggy-d4-mount1.jpg   Hot Bodies Cyclone D4 EP buggy-d4-mount2.jpg
Old 07-24-2008, 07:46 AM
  #765
Only problem is Hotbodies does not sell the undertray by themselves.It comes with the HB body.Oh well.I will stick with the stock body as will alot of other who like the undertray over chassis tape.
David,you were able to run the stock body without mods?
racenut123 is offline
