Hot Bodies Cyclone D4 EP buggy >
Old 11-11-2009, 09:41 PM
  #1531
hacker's Avatar
Trader Rating: 141 (100%+)
Originally Posted by yzracer758
try going up a tooth on your pinion, that might bring down your temps a bit.
must be some good stuff your smokin over there
hacker is offline
Old 11-12-2009, 10:59 AM
  #1532
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
If he is running on a large/fast track and undergeared, the motor would be running at high RPM's, causing higher temps. He would benefit from gearing up and bringing the RPM's/heat down.
BTW Hacker, thanks for your 2 cents and trying to help his issue...........
yzracer758 is offline
Old 11-12-2009, 04:06 PM
  #1533
I bought a 17 and 19 tooth pinion to experiment with this weekend so ill see how it goes. what is a safe range of temps for the motors to be? im new to electric so im a little lost
davo798 is offline
Old 11-12-2009, 04:09 PM
  #1534
Team Tekin
yzracer758's Avatar
160 degrees isn't something you should worry about too much. when it gets to the 180 degree mark then its time for concern. I would also make sure your slipper is tight.
Old 11-14-2009, 04:51 AM
  #1535
Some one can help me too, I have D4 WCE wit LRP TC comp and X12 7,5T, what pinion for smal technical track ( very low grip)
Thanks a lot for all help
mazzinga is offline
Old 11-14-2009, 09:48 AM
  #1536
Team Tekin
yzracer758's Avatar
17-18t pinion should do the trick.
Old 11-14-2009, 09:55 AM
  #1537
Thanks for your help
mazzinga is offline
Old 11-14-2009, 12:15 PM
  #1538
Trader Rating: 27 (100%+)
Gearing up a motor can lower temperatures if your stuff is just running down the straight reved out. My friend is running a 6.5R with a 20 I believe without temp issues. I run a 22/78 with a 7.5.
AxiomJacob is offline
Old 11-15-2009, 07:04 PM
  #1539
Default Regarding setup sheets question
on the setup sheets for the d4 is the ride height measured with the lexan tray on the buggy or measured with it off the buggy.
Watkins is offline
Old 11-15-2009, 07:14 PM
  #1540
revracr909's Avatar
Trader Rating: 21 (92%+)
I measure mine with it off.
revracr909 is offline
Old 11-15-2009, 09:05 PM
  #1541
nitro rat's Avatar
Trader Rating: 5 (86%+)
Hey guy's,
just need some help, would you guys recomend runing a 18 tooth pinion with a standard spur if using a 5.5 motor?
thank you
nitro rat is offline
Old 11-15-2009, 09:12 PM
  #1542
Team Tekin
yzracer758's Avatar
Originally Posted by nitro rat
Hey guy's,
thank you
On a big track, that would be right.
Old 11-15-2009, 09:14 PM
  #1543
nitro rat's Avatar
thank you Yzracer
  #1544
revracr909's Avatar
Hey guy's,
thank you
Ive ran a 6.5 with 80/ 18-19 good temps good power.
D4's ratio-2.4375
http://www.gearchart.com/ WORKS GREAT!!
Old 11-15-2009, 11:28 PM
  #1545
Where can I get a front shock tower brace . I,ve seen one from some So cal guys that came up to our race this last weekend. thanks
K Factor is offline
