Old 02-06-2007, 03:51 AM   #1
Default Need help with novak brushless setup plz
I've just got a Novak SS 5800 and put it into my ZX-5. The problem im having is there is no response from either the servo or motor. All I have is a red and green light permanently on.
The instructions say : Make sure input signal harness is plugged into throttle channel of receiver & ESC. Check throttle channel operation with a servo. Check wiring sequence of receiver signal harness. Green and Red status LEDs will both be on solid.
The gold connecter on the red to red is fine but the black seems like its a slightly different and won't fit properly but still makes a connection:
Any help would be appreciated, thankyou.
Orsm is offline   Reply With Quote
Old 02-06-2007, 08:08 AM   #2
foolio's Avatar
What happens when you hold the reset button for 5 seconds on the ESC?
foolio is offline   Reply With Quote
Old 02-06-2007, 11:05 AM   #3
erm, All 4 LEDs light up, then each they all flash 6 times. Then they individually light up in turn then it goes back to red and green perminant.
Old 02-06-2007, 12:34 PM   #4
AzBobby's Avatar
do you have the instructions for it? if not go to novak.com and you can view them online. it doesn't look like you did the initial programming, where you turn you throttle epa's all the way up and brakes to then hold the set button on the esc and turn it on and after it flashes the sequence of lights, that instructions say you pull the throttle to full until another light comes on, then you push to full brakes until another light comes on. once that is done it is programmed. from there you can then change profiles to the one you want.
GO TECH
AzBobby is offline   Reply With Quote
Old 02-06-2007, 01:01 PM   #5
AzBobby's Avatar
ok i found my instructions. transmitter on, hold set button on esc then turn it on, hold until red light comes on release set button. the pull throttle all the way hold it until light is solid green, then to full brakes until light blinks green then back to neutral trigger location light will turn solid red. from here when you hit the trigger the wheels will no turn, but not during programming. until you do this you wont have brakes either when you drive, you also won't have full top speed either. this should take care of your problem.
GO TECH
Old 02-06-2007, 01:32 PM   #6
Ok, thanks for help, I've turned the transmitter on as you said, held the set button down and turned it on until the red light comes on and released the set button. I've then held it all the way in but the red light is remaining on and not changing to green?
Old 02-06-2007, 02:12 PM   #7
AzBobby's Avatar
in troubleshooting it says to make sure your three wires are connected to the proper terminals on the motor and that the sensor harness is connected. if you push hard enough you can plug the sensor wire in backwards on the esc. also i see in your pic that you have replaced the yellow, blue and orange wires.looking at the top of the esc the wires are in this order from top to the bottom the red power to battery,orange wire to phase c on the motor,yellow wire to phase b on motor,blue wire to phase a on the motor, then black negative to battery. also i have the gtb esc but the wire order is the same. but i just went to novak page and read the instructions for the ss model and the trouble shooting says exact samething. after this all i can say is to call them and see what they say.
http://www.teamnovak.com/download/in...tPlusInstr.pdf
GO TECH
Old 02-06-2007, 02:38 PM   #8
Ok well I bought the esc and motor second hand and as far as you know it should be working, its wired up as the original owner had it and I bought it from a local club. I'll speak to Novak about it also, thanks.
Old 02-06-2007, 06:45 PM   #9
Paul_Sinclair's Avatar
Send a message via AIM to Paul_Sinclair
I think I know what your biggest problem is: you are in profile 6, which is meant for brushed motors only(!); but you've got a brushless motor hooked up. You said:
When all four lights are flashing, its informing you of the profile you are in. Profile 6 is for brushed motors, not brushless. Find the instructions about the profiles here .
Unfortunately, it looks like you might have damaged the speed controller; Novak warns you to never connect a brushless motor when the speedo is in brushed mode (profile 6). You can try to change it back to brushless mode by doing the following:
1. Turn the speedo off.
2. Remove the sensor wires from the speedo.
3. Press and hold the set-up button.
4. Turn the speedo on (while still holding the set-up button!).
5. When the blue and red LED's come on, release the set-up button.
6. The blue and red LED's will flash 9 times and then go solid.
7. When the blue and red LED's are solid, quickly press and release the set-up button.
8. The green LED will flash for a few seconds; after that turn the speedo off and reconnect the sensor wire.
Go ahead then and hook it back up and try it out. Hopefully it will work for you, if not you'll probably need to talk to Novak.
X Factory R/C - Viper R/C - Futaba - Darkside Designs - Lunsford - MIP - B Fast Performance Diff Parts
Paul_Sinclair is offline   Reply With Quote
Old 02-12-2007, 03:11 PM   #10
Thanks for the information, ESC and Motor have been returned.
Old 02-03-2009, 08:10 PM   #11
Mattman1147's Avatar
Default having the same issue
well I have had the same issue and always after i connect the sensor wires it goes bask to solid red and flashing green.
any help do i need a new ESC or MOtor
Mattman1147 is offline   Reply With Quote
Old 02-04-2009, 12:38 AM   #12
JeromeK99's Avatar
I know it might seem silly... but are you sure the battery you are using is charged? I've seen folks at the track with GTBs that have the same prob until they changed batteries...
Jerome
JeromeK99 is offline   Reply With Quote
Novak SS 5800 brushless setup Sage R/C Items: For Sale/Trade 4 01-29-2008 06:17 PM
For sale - Novak 3.5 brushless setup $257 hype Australia For Sale/Trade 17 12-20-2007 05:12 PM
WTB Brushless Setup! LRP,Novak,etc. jtracker R/C Items: Wanted to Buy 2 05-29-2006 07:14 AM
F/S Novak 5800 Brushless Setup dragracer72nova R/C Items: For Sale/Trade 13 08-20-2005 05:42 AM
Looking for Novak Brushless SS5800 setup LosiFromHell986 R/C Items: Wanted to Buy 3 08-21-2004 08:43 PM
