Old 02-05-2007, 09:34 PM   #1
chris c's Avatar
Trader Rating: 60 (100%+)
Default 13.5 novak brushless gearing
Just picked up a 13.5 brushless I need a starting point for gearing
Losi xxx-cr and a Losi [email protected] truck
Thanks all
Chris
chris c is offline   Reply With Quote
Old 02-06-2007, 01:01 AM   #2
chris c's Avatar
buller???????
Old 02-06-2007, 07:14 PM   #3
chris c's Avatar
well???? lol
Old 02-06-2007, 08:16 PM   #4
jgroenhof's Avatar
Originally Posted by chris c
Just picked up a 13.5 brushless I need a starting point for gearing Losi xxx-cr and a Losi [email protected] truck
Thanks all
Chris
Chris, for racing at SoCal I would say, a 15t pinion.
Anywhere else I'd probably go up a tooth or two from your P2K2.
Isn't the 13.5 supposed to be a torque motor?
But remember 15 at SoCal.
Johnny G
OCRC.
jgroenhof is offline   Reply With Quote
Old 02-07-2007, 11:10 AM   #5
chris c's Avatar
I talked to charlie at novak and he said 2 teeth higher than what a brushed motor gets....guess i will play with it!
Old 02-07-2007, 04:42 PM   #6
Send a message via AIM to trashedmaxx
I run a 20-21 on my B4 with a monster. I went with a 23 on the 13.5 I tried a 24 but my local track is high bite so the 23 felt better. I have not tried the 13.5 in my truck yet.
trashedmaxx is offline   Reply With Quote
Old 09-18-2007, 08:52 AM   #7
Trader Rating: 75 (100%+)
Send a message via Yahoo to Paul_67
I just got a 13.5 for me XXX-CR and checked the Novak site for gearing info. They are saying to gear it with a FDR of 7. If I did the math right, that would be a 27t pinion with the stock 78t spur. That sounds way too high.
Paul_67 is offline   Reply With Quote
Old 09-18-2007, 09:08 AM   #8
Sneaky Pete's Avatar
I'm using 22/86 in my MF2. I thought it was too high but the motor/esc barely gets warm.
Sneaky Pete is offline   Reply With Quote
Old 09-18-2007, 09:51 AM   #9
mfishel's Avatar
It may sound way high, but that seems to be what they want. Here at Planet a lot of racers have made the switch to 13.5s, and on the B4 they are running 24t to 26t with an 81.
mfishel is offline   Reply With Quote
Old 09-18-2007, 10:32 AM   #10
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
in my b4 i ran 81/24 for a good 8-10 minutes, pulled it off and temp'd the motor at about 80-deg F (65-deg air temp) and the gtb was 114-def F (without the fan - fan is mounted now though)
with temps like that i was thinking about going to 81/26 and 87/22 in the truck....but its 87/20 right now in the t4 till i run this thursday.
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 09-18-2007, 10:32 AM   #11
mkdut's Avatar
Trader Rating: 19 (100%+)
It's not too high at all. I ran the 13.5 in my RB5 with a 78t spur and a 17t pinion. The motor and ESC had a temp under 120 degrees. On a bigger track I think you could use an even bigger pinion if it would fit.
mkdut is offline   Reply With Quote
Old 09-18-2007, 10:36 AM   #12
wd40prerunner's Avatar
Trader Rating: 8 (79%+)
Im running 81/22 on my b4 and my motor runs super cool and very smooth. i might try to go up a couple of teeth.
wd40prerunner is offline   Reply With Quote
Old 09-18-2007, 10:38 AM   #13
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
I'm running my RB-5 at 76/31 right now and it comes off at 80-something. It's a REALLY big track, but I've always run at least 27-29. There's almost no such thing as "too high" with a sintered 13.5. They have crazy torque.
FYI -- the onroad guys run FDR's from 3.50 to 4.50, depending on the track.
Turbo Joe is offline   Reply With Quote
Old 09-18-2007, 10:55 AM   #14
RaceAce701's Avatar
Trader Rating: 86 (99%+)
86/24 in a MF1 It was 9 teeth over what i ran with a monster stock
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 09-18-2007, 10:57 AM   #15
johnnyboy's Avatar
Trader Rating: 28 (97%+)
Gear it to the moon!
In my RB5 I am running 27/78...others around here are running 26-28T as well.
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Novak has updated the Brushless Gearing Charts CarbonJoe Electric On-Road 21 02-19-2008 06:18 PM
Gearing for novak brushless thekthai Singapore R/C Racers 0 08-14-2007 08:27 AM
XXXT Novak Brushless 5800 gearing Andrew_XXXs Electric Off-Road 1 04-27-2004 09:37 PM
novak brushless gearing ant Australian Racing 4 09-21-2003 07:58 PM
gearing for novak brushless? Elk666 Electric On-Road 0 04-04-2003 10:46 AM
