Old 02-03-2007, 10:49 PM   #1
Born2Lose's Avatar
Default Adding weight to B4
Where is the best place to add weight to the B4? How do you but it on the chassis?
Born2Lose is offline   Reply With Quote
Old 02-03-2007, 11:08 PM   #2
AndyMoore's Avatar
Trader Rating: 54 (100%+)
Send a message via AIM to AndyMoore
Directly infront of the transmission, on the t-plate (1/2oz - 1oz). Some guys are adding another 1/2oz total on either side of the chassis in the triangle recesses.
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 02-04-2007, 12:22 AM   #3
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Also try moving the battery more to the front of the chassis. Also the electronics as well.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 02-04-2007, 02:35 AM   #4
Trader Rating: 26 (96%+)
Where you place the weight should depend on your driving style. The half ounce in front of the trans is a good move. Then if you want your car to be more forgiving then place weights wide on the chasis. If you want it more responsive then you place ne weights needed to reach limit in the battery trey. Something else you can do on tight low hp tracks is replace 2 cells w/ flat lead weights.
party_wagon is offline   Reply With Quote
Old 02-04-2007, 05:24 AM   #5
Here is a perfect picture of where it should go. AE sells the weights.
http://www.rc10b4.com/forum/showthre...t=B4+Race+mods
NoEffects6 is offline   Reply With Quote
Old 02-04-2007, 08:30 AM   #6
wd40prerunner's Avatar
Trader Rating: 8 (79%+)
this mod is great it made my buggy hook up tons and it made me be able to get on the gas harder and not spin out. I have 1oz in front the trans and 1/4oz on both sides of the car.
wd40prerunner is offline   Reply With Quote
Old 02-04-2007, 12:10 PM   #7
Born2Lose's Avatar
What do you use for weights ?
Old 02-04-2007, 12:39 PM   #8
annie_himself's Avatar
Send a message via AIM to annie_himself
You use weights, any LHS should have them.
annie_himself is offline   Reply With Quote
Old 02-04-2007, 01:17 PM   #9
I don't know the part number but Associated sales them for like 3 bucks for I think it 4oz lead that's in 1/4 oz chunks
Old 02-04-2007, 01:34 PM   #10
Born2Lose's Avatar
Thanks for the help !
Old 02-04-2007, 04:36 PM   #11
WheelNut's Avatar
Send a message via MSN to WheelNut
Most tire shops will also have stick on weights, you can probably get a ton of them for next to nothing.
•Brad Comis
WheelNut is offline   Reply With Quote
Adding weight for Lipos F N CUDA Electric Off-Road 42 01-16-2008 01:34 PM
Adding Weight to Chassis shaggys40oz Electric On-Road 7 10-20-2007 04:11 PM
Adding weight to Lipos? F N CUDA Electric On-Road 18 07-12-2007 01:11 AM
Adding some fun to the series. mxrich Georgia Racing 1 01-15-2007 05:56 PM
Adding Weight to the chassis TRF-Powered Electric On-Road 16 06-05-2003 11:27 PM
