Old 02-14-2007, 09:18 PM   #61
annie_himself's Avatar
Send a message via AIM to annie_himself
64 pitch is for on-road but I just threw it out there. Explain the gear reduction thing with two spurs.
annie_himself is offline   Reply With Quote
Old 02-14-2007, 09:33 PM   #62
eds24's Avatar
Trader Rating: 56 (100%+)
Send a message via AIM to eds24 Send a message via Yahoo to eds24
ok since i can only use t4/b4 spurs on the slipper and the bigget t4 spur is 87t he said i could get a 96t cut the center out and screw that on to the t4 spur i wouldn't use the t4 spur it would be just a mount.
eds24 is offline   Reply With Quote
Old 02-14-2007, 09:46 PM   #63
So the T4 spur would be just sitting there?
Old 02-14-2007, 09:48 PM   #64
eds24's Avatar
Correct it would be used as a mount and to mount the slipper on but it would not be used as a drive so it would just be sitting there.
Old 02-14-2007, 09:51 PM   #65
I don't see how it reduces gear reduction though. Sounds like your trying to have a fake 2 speed to me..lol
Old 02-14-2007, 09:59 PM   #66
eds24's Avatar
It helps with the gear ratio. It will give me more torque so that the motor doesn't have to work as hard.
Old 02-14-2007, 10:03 PM   #67
I guess I will see..
Old 02-14-2007, 10:11 PM   #68
Trader Rating: 26 (96%+)
If you put an actual race oriented tread on the car it will make the tires smaller and thus reduce the gear ratio a good bit. Not to mention, I would think that something along the lines of a 10t/87t combo would work fine for what your wanting to do.
party_wagon is offline   Reply With Quote
Old 02-14-2007, 11:08 PM   #69
eds24's Avatar
ok I might have to do that. Right now I don't have the money
Old 02-15-2007, 05:21 PM   #70
smac's Avatar
That spur gear mod is not a gear reduction it is just using a taller spur. The slipper clutch that he has will only accept T4/B4 spurs that go up to 87t. So he can use the 87t spur that fits into the slipper and bolt a bigger spur to that gear. The motor pinion then would only make contact with the taller spur.
eds24- if you shave much more than 1/8" then you will be cutting into the inside of the gearbox. You then would have to mill out the chassis so the diff gear would not contact it and you would allow alot of dirt to start entering the box.
If you are gonna try the tall spurs though, then I would not lower the gearbox at all. You do not want that gear hanging out the bottom of the chassis. If you are looking for a quick fix, then add shims under the inner suspension mounts and raise the upper tie rod as well. Try to get them all close to parallel for a starting point.
Scott McDonald
VelocityRC/Scale Motorsports/Checkered Flag Hobbies/SmacTrac
smac is offline   Reply With Quote
Old 02-15-2007, 06:22 PM   #71
eds24's Avatar
I would just be cutting the posts more then 1/8th then mill a square in the chassis for the diff to go into. I would still keep everything sealed.So for the rear I may have to make a new link mount for the shock tower so that I can lower the inside link becuase I can't raise the outside link. Peace Ethan
Old 02-15-2007, 06:39 PM   #72
I get it now.
Old 02-16-2007, 12:03 AM   #73
eds24's Avatar
A bit slow eh annie? lol I got some pics witht hte truck body on it.. I put a T3 body on it and this is how it came out. Also there are pics of the auto graphs I got from Travis Amezcua. Peace Ethan
Old 02-17-2007, 11:04 AM   #74
Its good that you try to be funny EDS, is good to have confidence in yourself. It looks good with that body on it, I want one.
Old 02-17-2007, 12:22 PM   #75
Stonzy's Avatar
Send a message via ICQ to Stonzy Send a message via Yahoo to Stonzy
Looks real good with that truck body on it
Team Manager "Fantom Racing".
Proudly Sponsored by Fantom Racing, “More Power To The People”.
T4.1, T4, B4.1, TRF501X, Dyna Storm, Hornet, Top Force, XXX-SCT, Slash 2wd,
Multiple National Champion and State Champion from 2003 - Current
Stonzy is offline   Reply With Quote
Project Team Kassanova TR3 V2 (Tc3 Truggy) eds24 Electric Off-Road 28 06-28-2009 10:20 AM
Project Team Kassanova K2 buggy eds24 Electric Off-Road 89 05-06-2009 10:57 PM
WARNING ---> REMOTE CONTROL HOBBY ADDICT/FAN <--- WARNING AlphaDOG Web Links 2 08-24-2008 04:13 PM
custom rs4 project 56k warning many big pics 2ffu Electric Off-Road 6 12-23-2004 11:37 PM
hyper-7 truggy project trade for Rc10gt or xxxnt mtrucker R/C Items: For Sale/Trade 3 12-12-2004 08:16 PM
