Old 01-26-2007, 05:42 PM   #1
chris c's Avatar
Trader Rating: 60 (100%+)
Default XXX-4 G+ hop ups???'s
I looked thru the xxx-4 thread but was wondering if someone could let me know what hop ups i should do
I have the alum outer pivots and inner....xxx-s 1 way etc
My ? was should i run inner and outer or just the outer to make a weak spot?
Also i saw a thread about making a brace fro the diff covers,,,,i can see to find it.
Thanks all
Chris
chris c is offline   Reply With Quote
Old 01-26-2007, 08:19 PM   #2
Thanks all
Chris
I have seen guys run both aluminum pivots inside and out,and just on the outside.I only have the outside,mainly just because I haven't bought the aluminum inners yet.ALso http://amainraceway.com sells aluminum front spindle carriers.I have yet to be there when they have them in stock but are nice.I want those more than anything.I pop the stockers just off of jumps.The pivot supports I've only broke them when I screw up and hit something.
Something I haven't figured out yet is to keep my slipper tight. No matter what i do I havent got a good run yet lately with out it coming loose.I am going to try locktite on it next.Other than that I like mine.
Jammin"145 is offline   Reply With Quote
Old 01-26-2007, 10:25 PM   #3
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
What are you wanting to do? Is it for racing. The XXX-4 G+ is already mostly fully hoped up apart from a one-way and aluminum parts. I haven't broken a diff cover yet but I here it happens quiet alot
Cheers
Drift_Buggy is offline   Reply With Quote
Old 01-27-2007, 01:19 AM   #4
chris c's Avatar
[QUOTE=Jammin"145]I have seen guys run both aluminum pivots inside and out,and just on the outside.I only have the outside,mainly just because I haven't bought the aluminum inners yet.ALso http://amainraceway.com sells aluminum front spindle carriers.I have yet to be there when they have them in stock but are nice.I want those more than anything.I pop the stockers just off of jumps.The pivot supports I've only broke them when I screw up and hit something.
Thanks so much I think it will just try it and see if she breaks...
Do you have a older version xxx-4...They(losi) updated the slipper to adjust backwards so it wont come loose.
And as for racing yes thats my new addiction
Old 01-27-2007, 07:52 AM   #5
It's a G+ model that I bought late last spring.I haven't ran it much,only a couple races outdoors last summer,my local track is mainley nitro turnout and now I've been going into A-main raceway which is indoors and all 1/10 scale.I want to get it figured out for sure.The thing is fun when it hooks up.
Old 01-27-2007, 01:17 PM   #6
RussB's Avatar
Send a message via MSN to RussB
the a-main raceway castor blocks are nice. the bj4 castor blocks can be modified to fit a xxx4, and you can use an actual hinge pin instead of those pin-screws.
the aluminum inner pivots look nice, but the plastic ones are cheap insurance. in a hard crash the aluminum pivots won't give and can crack out of the chassis. the plastic pivots will just give.
RussB is offline   Reply With Quote
Old 01-27-2007, 02:56 PM   #7
How much modification? Never heard of this. Must be cheaper than Amain's $37 each aluminum ones
Cheers
Old 01-27-2007, 08:04 PM   #8
chris c's Avatar
Cheers
yes info please!!!!!
Old 01-28-2007, 12:11 AM   #9
RussB's Avatar
drill out the hole where the cvd passes through with a 1/2" bit otherwise the cvd won't pass through it, although this step may be optional if you run front universals.
drill out the hinge pin hole on the castor block and the hinge pin hole in the arm with the appropriate sized bit for a standard size hinge pin. you'll want to find the closest length pin and shim up the slop.
and yeah, it's much cheaper than the $39, the bj4 parts cost $19.99 and i had the necessary spacers and hinge pins in my misc crap. it also beefs up the front end quite a bit since there's an actual hinge pin there.
