Old 01-26-2007, 12:51 PM   #1
Send a message via AIM to steven19
Default need gearing help
i have a rc 10t yes its old school i just put a epic 27 turn hand out motor from one of the nats and i currently have it geared 20/81 i think thats right and its just a dog like none other what would you guys gear it the track i run on is pretty small however the truck will just be used to bash around and have fun
steven19 is offline   Reply With Quote
Old 01-27-2007, 03:32 AM   #2
Suspended
wingnutracing28's Avatar
there are 3 reasons it could be a dog. first is yes you may need a 19 pinion, next is batteries( if your not using 4200 or 4300's) and then the speed control can all hold you back. the track will let you know your dying out there. to really compete you will need the newest esc from Novak or lrp. but i don't recomend them as they always have troubles with their electronics. then get better batteries. then don't believs that 17t on the side of your rtr truck. its not the same even as our 27t stock motors, much less a true mod or 19t motor.
wingnutracing28 is offline   Reply With Quote
Old 01-27-2007, 06:03 AM   #3
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
you don't need the newest esc and the newest batteries....
im running an novak gt7 and orion 3300sp2s, but im using a new trinity co27 motor and trinity cobalt mods too....the most important thing is a good motor with the correct gearing....good batteries and a good esc are important, if your running the rtr esc and 3300 stick packs you will see a disadvantage...
http://www2.towerhobbies.com/cgi-bin...?&I=LXKSB1&P=0
just as good as the novak gtx for club racing
http://www2.towerhobbies.com/cgi-bin...?&I=LXLXT7&P=0
best stock motor available in my opinion (except for the epic xx stock - illegal motor - has ball bearings)
http://www2.towerhobbies.com/cgi-bin...?&I=LXHWT4&P=0
great packs for club level racing i have 6 packs that im still using, all take 3000-3200 charge after 2 1/2 years with voltages from 1.180 to 1.197
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 01-27-2007, 02:34 PM   #4
Default gearing
this is an old school car i just want it to run decent and bash it around give me a gear ratio right now im using a 3600 venom pack and it has the high end tekkon speed control from about 8? years back i just want it to go faster so i can bash it along with let freinds drive it so they will build interest as well
Old 01-27-2007, 02:46 PM   #5
Suspended
well an 81 spur is quite small for a truck, causing a loss of low end torque which you need for truck. and for it to impress it needs to take off, in front of your buddies. past that against any other newer trucks out there it just won't stay with them. the internal gear ratios have changed so much since when yours was built.
Old 01-27-2007, 02:47 PM   #6
Suspended
i just remebered that teambirdman.com has a gear ratio chart in it. if you can look up what your gear ratio is you will then be able to what the best pinion/spur combo would be.
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
