Old 03-01-2007, 07:44 PM   #121
rustyvan's Avatar
Default Hey guys I found a deal on a good pipe
Hey guys I went to nitrohouse.com and they have a rippled pipe for $9.95 plus shipping and it comes in purple or blue and they told me that it makes a big increase over the stock pipe on the xxxnt rtr and the rippled affect in the pipe increases the flow of fuel for a more even mixture.
You can't beat the price. Also he told me it will bolt up fine to the stock header with no problems.
rustyvan is offline   Reply With Quote
Old 03-01-2007, 07:46 PM   #122
jbmccoy205's Avatar
Trader Rating: 47 (100%+)
one more is there a websight that goes through the different compounds of tires.....say softest to hardest? if not what is the softest compound? thanks guys
jbmccoy205 is offline   Reply With Quote
Old 03-01-2007, 07:51 PM   #123
LOWGEARED's Avatar
This is the TEAM LOSI tire chart !!! It covers just about everything you need to know!!
http://www.rchobbies.org/team-losi_tire-guide.htm
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 03-01-2007, 07:53 PM   #124
LOWGEARED's Avatar
deleted for some odd reason
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-01-2007, 07:54 PM   #125
LOWGEARED's Avatar
I just bought a DRAKE PIPE!!! but I will keep that in mind if mine gets smashed again
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-01-2007, 08:58 PM   #126
jbmccoy205's Avatar
Aaron If you were to replace the .15 motor on the rtr what would be your choice if money was not an option along with the pipe and manifold?
Old 03-01-2007, 11:15 PM   #127
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
The OS .12 CV-R is a great choice as it is quite fast but also very easy to control. I wanted to spend $200+ on an engine, but it just wasnt needed. I was running with Peak .12s, the Drake .12 and and the Fantom .12 and it held up fine on the back straight but it was very easy to control while cornering. For $100 it is a damn good engine. Though my next will be the Drake .12 IF I get a chance to run at Revelation more than 1x a month.
rezenclowd3 is offline   Reply With Quote
Old 03-02-2007, 12:02 AM   #128
LOWGEARED's Avatar
Ya the OS is gonna be my next one too!!!! Tough ,not expensive
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-02-2007, 01:22 AM   #129
Aaron Waldron's Avatar
If money is no problem? The Trinity Platinum Drake engines. It's the most powerful gas truck engine I've ever run, and it's even more driveable than many of the other engines I've used. Combined with the Drake pipe, it's crazy how smooth the powerband is, yet it has grunt like a CRF450R pulling through the gears, haha.
If you're looking for something a little less expensive, the Drake Signature Series motors are super smooth and really easy to drive, kinda like an electric car with a 19 turn. Not that they lack power, they're just really easy to drive aggressively.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-02-2007, 07:36 AM   #130
Originally Posted by LOWGEARED
Well jew get er runnin yet?
Ya man, took her down to the LHS yesterday, and the guy tuned it up for me, adjusted brake, etc. What a difference! He told me he had set it up rich for the break in on the piston and sleeve, and now this thing MOVES
How's your truck running with the new exhaust pipe?
J30Guy612 is offline   Reply With Quote
Old 03-02-2007, 10:28 AM   #131
LOWGEARED's Avatar
It runs a little differant Im still waiting on the steering spindles?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-02-2007, 03:46 PM   #132
LOWGEARED's Avatar
Default Aaron
Hey guy ,,,
Im using a coke can to set my toe in and outs...
I know its not the best method !!!!! Kinda redneck too!! All I do is bash with it right now.. How would 1 degree toe in look up against that can in millimeters!!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-02-2007, 03:52 PM   #133
Just a bit of a gap is all you're looking for. Maybe 1-2 mm? I've never really thought of it that way...haha.
www.liverc.com
Old 03-02-2007, 04:24 PM   #134
LOWGEARED's Avatar
Always thinking though!!!
I have to use the primative method!!! Some can do it by sight or feel!!
Thanks my rear tires seem to be eatin away on the insides more than anywhere else so I might go 1 degree out from negative..
They came with about 3 in I think!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-02-2007, 04:41 PM   #135
The rears, you can usually get away with running them straight up and down, or even a little bit positive camber at right height.
www.liverc.com
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 05:19 PM
the official r/c picture thread aftershock Chat Lounge 3 11-29-2007 12:58 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 02:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 11:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 04:09 PM
