Old 03-09-2007, 09:52 PM   #196
LOWGEARED's Avatar
That blue trail should only be really visable reaching topside of the acceleration correct?
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 03-09-2007, 09:56 PM   #197
FrankBlack's Avatar
Yeh, you should still have smoke coming out the stinger on all ranges though.
FrankBlack is offline   Reply With Quote
Old 03-10-2007, 09:10 AM   #198
Originally Posted by Aaron Waldron
The AD2 front and rear suspension pieces are a little more beefy than the RTR parts, and using the AD2 front and rear axles will allow you to use the same wheel front and rear.
Hi there Aaron,
I now own xxxnt RTR and wants to use the AD2's rear axles so that I can use the same wheels.. can you give me the part numbers of the things I need to buy. which wheels will I have to use? the front or the rear? do I have to buy the quick change thingy? thanks for ur answers
muzamil is offline   Reply With Quote
Old 03-10-2007, 05:12 PM   #199
LOWGEARED's Avatar
Isnt it true that some fuels dont smoke alot!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-11-2007, 01:47 AM   #200
FrankBlack's Avatar
I couldnt tell ya buddy. anyone??
Old 03-11-2007, 03:56 AM   #201
Aaron Waldron's Avatar
Some fuels don't produce much smoke. Always a little bit, but not enough anymore to recommend someone to tune for a trail of "healthy smoke" coming from the pipe.
muzamil - Give a man a fish, he eats for a day. Teach a man to fish, he eats for the rest of his life. I could look up the part numbers for you, or I could link you to the same thing I would look at...haha.
http://www.teamlosi.com/Products/Def...rodID=LOSA0846
These pages are available for all of Losi's kits. You can download the manual to the AD2 on that page, and find the part numbers for the upgrades you're looking for. To put the AD2 rear end on your truck, you'll need the rear pivot block, arms, hubs, hub bearings, axles, dogbones, and hardware. It's best to do it all at once, your truck will work better with the entire conversion versus just a couple of the parts here and there (not to mention most of it won't fit at all, haha).
If you do the rear end conversion, and get the front axles from the AD2, you'll be able to use the same wheel (A-7760, I think?) front and rear. The AD2 rear axles can use a threaded axle and locknut, but the quick change system works fine and there's really no reason to run the nut.
Fuels with lots of castor oil in them provide more protection against lean-conditions and can make the engine easier to tune, but as you guys have found out, will make the engine run hotter and with less power. Reason being, a 20% nitro fuel with 16% oil, will have less alcohol in it than a 20% nitro fuel with 12% oil (duh). Oil burns at a hotter temperature than alcohol does.
At least, that's how I understand it.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-11-2007, 10:46 AM   #202
LOWGEARED's Avatar
Thats what I figured I appreciate you clearing that up ! Cause I have visible trails through top range just not as much through low to mid..
Odonnells 20% and it dosent say the lube % on it so I figure they just know what theere doing with it cause it runs great!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-12-2007, 06:19 AM   #203
Thanks Aaron for the info. actually i just need to know what are the parts that i should change and i think i will follow your advice. just wanna make sure i'm buying the right parts so as not to waste money on unnecessary parts and if possible to minimize cost. tq again
Old 03-12-2007, 08:00 PM   #204
jbmccoy205's Avatar
Trader Rating: 47 (100%+)
I'm looking at buying a used hpi ss .12 that has been recently pinched by osrockets.........WHAT does pinched mean?
jbmccoy205 is offline   Reply With Quote
Old 03-12-2007, 08:40 PM   #205
jbmccoy205's Avatar
never mind i did a search and found the answer
Old 03-14-2007, 01:50 PM   #206
LOWGEARED's Avatar
Does anyone know how to fix a wobbly jump in the front tires??
Its not a side to side wobble!!! Its like the tire needs to be balanced!!! When I spin it they always return to the same specific point I started! Anyone understand what Im sayin?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-14-2007, 01:55 PM   #207
Modeling clay, or weight tape from a motorcycle store work very well for balancing tires.
If glued evenly and the foam stays flat, they should be reasonably balanced anyway. But you can always make it better.
www.liverc.com
Old 03-14-2007, 02:02 PM   #208
LOWGEARED's Avatar
So I would probably stick it on the opposite side Its a pretty bad problem when I hit the brakes my front end jumps bad!
What caused that Ballooning the fronts?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-15-2007, 10:53 PM   #209
jbmccoy205's Avatar
Default motor question
so i bought a used truck it came with a slide carb, 12r sc hpi, the thing runs awsome but everything i read is that i need the rotary carb can i take the carb off my .15 that came with the rtr and put it on the .12? or just stay with slide.......?
Old 03-16-2007, 02:42 AM   #210
FrankBlack's Avatar
You can swap the carb around, but i cant see why you would "need" a rotary carb, if its fine i wouldnt bother swapping it out, id prefer a slide carb.
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 05:19 PM
the official r/c picture thread aftershock Chat Lounge 3 11-29-2007 12:58 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 02:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 11:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 04:09 PM
