Old 03-08-2007, 07:04 PM   #181
jbmccoy205's Avatar
Trader Rating: 47 (100%+)
Aaron thanks for your help I just said screw it and bought a AD2........Now when it breaks I'll be back
jbmccoy205 is offline   Reply With Quote
Old 03-08-2007, 08:22 PM   #182
LOWGEARED's Avatar
I suppose the Stampede tires will work until you get new ones, just make sure your diff and slipper don't overheat. The taller tires will put more stress on the drivetrain.[/QUOTE]
Would 2 or three tanks of casual driving be bad for the diff with those tires?
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 03-08-2007, 10:24 PM   #183
Aaron Waldron's Avatar
Not necessarily, but one good stab of the throttle on a high-traction surface with those tires could roast the tranny.
It's not a big deal, just make sure everything is adjusted correctly. It'll be fine.
jbmccoy - That's one way to fix it, haha.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-09-2007, 08:40 PM   #184
LOWGEARED's Avatar
Those stampede tires are like plastic compared to the losi tires !!!! It does fine
except for that!!! I probably could pull off a few backflips with them on!!
They baloon like crazy!!!!
If Im sitting at Idle and it loads up quick does that mean I need to lean the HSN some?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-09-2007, 09:13 PM   #185
FrankBlack's Avatar
When you stop ripping and let it idle does the idle start high then drop down?
FrankBlack is offline   Reply With Quote
Old 03-09-2007, 09:20 PM   #186
LOWGEARED's Avatar
No !!! It just Idles right then starts to Idle low like its gonna die!!!
On normal runs what are you temps after a WOT pass or too?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-09-2007, 09:23 PM   #187
FrankBlack's Avatar
Mine struggles to break 100C (im running 16 nitro, 10 syn oil and 2 castor). So yours idles fine then drops down to a slow idle?, that is usually a indicator that you need to lean off the bottom and remembering that the idle stop screw will need adjustment too after you touch the bottom end.
Old 03-09-2007, 09:25 PM   #188
LOWGEARED's Avatar
Whats 100 degrees C in Farienheit? Mine was pushin 260 F' today but that was after a good hard rompin!!!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-09-2007, 09:27 PM   #189
FrankBlack's Avatar
100C is 212F. What fuel mixture you running?
Old 03-09-2007, 09:30 PM   #190
LOWGEARED's Avatar
So I will have to richen my hsn real good too!!! But it gets good acceleration all the way to the top !!!! So that might be right where its at!!! and theres smoke!!
So tommorra Ill lean out the lsn more!!! Thanks
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-09-2007, 09:32 PM   #191
FrankBlack's Avatar
I find high castor oil fuel tends to make any motor ive had run hotter.
Old 03-09-2007, 09:33 PM   #192
LOWGEARED's Avatar
I run O'donnells 20% Racing fuel!!!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-09-2007, 09:37 PM   #193
FrankBlack's Avatar
Well you should be fine with that stuff, im not up to date on what mixtures they run but being race fuel im guessing it has only small % of castor.
Old 03-09-2007, 09:41 PM   #194
LOWGEARED's Avatar
I mean when I find it to be hot its cause I get carried away with the throttle and just blast through fields!!! So that would make any motor hot unless it has 2 gears or more right?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 03-09-2007, 09:50 PM   #195
FrankBlack's Avatar
I just did the C to F conversion on 260F and that should be fine, i used to tune by how hot they get but now if it sounds nice and im getting the nice blue trail of smoke i leave it and dont worry about the temp. But yeh 260F is by no means anything to worry about.
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 05:19 PM
the official r/c picture thread aftershock Chat Lounge 3 11-29-2007 12:58 PM
Official MT2 RTR Thread PowayLAX1 Electric Off-Road 18 03-20-2007 02:03 PM
LST Official Thread Whipple81 Monster Trucks 0 10-06-2004 11:30 AM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 04:09 PM
