Old 01-18-2007, 07:42 PM   #1
Default xxx nt help!!!
hey guys i got a xx nt the other day oi broke it in 4 tanks ran super rich but today i go to start it and nothing well so far iv gotin to the point where it starts up but doses not idel it just shuts off plz i need any help i can get thx guys
tuner_taz is offline   Reply With Quote
Old 01-18-2007, 07:51 PM   #2
LOWGEARED's Avatar
Have you tried setting hsn ,lsn, and idle back to factory settings
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 01-19-2007, 03:59 AM   #3
ya that where its at but my idel needel i have no ideal where to set since it dosnt tell me in the manal
Old 01-19-2007, 04:43 AM   #4
lol yester day it would start and shut off today nothing god dam nitro engins sigh im taking it to my lhs see what they tell me
Old 01-19-2007, 05:13 AM   #5
LOWGEARED's Avatar
Man do that !!! I am just fixin to buy one of those too tell me if its big trouble
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 01-19-2007, 07:40 AM   #6
Trader Rating: 24 (100%+)
Always check the glow plug, they can go out easily during break in perid
MNRC Committee
Josh's "Pit Guy"
Bones Brew Fuel Dealer
Thank you to his sponsors Mugen, J-Concepts, The Nitro Shop, Loosenuts Racing, Savage RC Motorsports, Ford Designs.net and FTR...
Jeff Ford is offline   Reply With Quote
Old 01-19-2007, 03:18 PM   #7
LOWGEARED's Avatar
Just wanted to see if you got it fixed yet??????
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 01-19-2007, 05:01 PM   #8
umm not yet hobby shop was to busy today they told me to come tommaro in the moring no it not big trobel its just that for some resonei messed it up wile trying to tune it thats what the hobby shop its a grate littel truck come with a glow plug too so if u dont have one u dont need to get 1 i got another and use the one that came with it as a back up since it runs on c battries will keep u guys posted
Old 01-19-2007, 05:31 PM   #9
LOWGEARED's Avatar
The glow plug you got is it still good check the spring inside it for bad discolloration or if its still there!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 01-19-2007, 05:32 PM   #10
streetracer745's Avatar
Send a message via AIM to streetracer745
im guessing your new to nitro engines. check your plug. if you ran it really rich during break-in, then it might be dead. take it out and conect it to your plug warmer to see if it turns orange. the coil will light up if its good. if not then its dead.
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 01-19-2007, 05:33 PM   #11
also check the plug warmer itself. the battery could be dead. thats happened to me before.
Old 01-19-2007, 10:59 PM   #12
Bigedmond's Avatar
Trader Rating: 18 (100%+)
sounds liek plug is not getting hot enough. Which means, either plug bad, or warmer dead.
When breaking engines in, you will probably fowl up 1 plug. its normal, thats why i carry 5 plugs for every motors. They go bad, and you just have to accept it.
Bigedmond is offline   Reply With Quote
Old 01-19-2007, 11:14 PM   #13
Just a little tip, If you want us to understand what you are saying, use punctuation, and try to spell as best you can ( not that I am perfect, but this is very jibberish and ran together). You should always keep an extra glow plug in the correct size and temperature. It also helps to have more than one charged glow igniter.
HTH
Rod
gatermaxx is offline   Reply With Quote
Old 01-20-2007, 05:33 AM   #14
sigh sorry it was geeting kinda late. umm the plug and charger are good first thing i checked
im kinda new but kinda not i kow how to rebuild a engine and how to brake it in but have no idea how to tune one (thats the part i messed up in)
Old 01-20-2007, 08:11 AM   #15
well if everything is good plug wise, try leaning the engine. if its too rich you will choke it out. ive done it before. but be careful cause if you go too lean it will mess up the engine.
