Old 01-28-2007, 09:27 AM   #61
streetracer745's Avatar
Send a message via AIM to streetracer745
TRX2.5R demensions:
On-Center Mounting Holes, Front to Rear: 11mm (.433")
On-Center Mounting Holes, Side to Side: 31.4mm (1.24")
Back of engine(recoil)to front of drive washer: 73.2mm (2.88")
Height: 97.3mm (3.83")
TRX3.3 demensions
Distance between mounting holes same side: 0.39" (10mm)
Distance between mounting holes opposite side: 1.2" (32mm)
Distance from center of engine to front bearing: 1.2" (32mm)
Distance/bottom of mounting flanges/top of cylinder head: 3.5" (88mm
Width of mounting flanges: 44mm
they are all but exactly the same
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 01-28-2007, 08:03 PM   #62
LOWGEARED's Avatar
damn done your homework!!!!!!
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 01-28-2007, 08:17 PM   #63
only takes a few seconds to get them. and those might not be exact demensions. those arent from traxxas. but they are all but exact if they arent right
Old 01-28-2007, 08:22 PM   #64
LOWGEARED's Avatar
Hey I give you the benifit of dought here! Im not gonna stick one on a losi..... just cuz you know Ford with Chevy parts... Sounds wierd. did you see that video I posted on a new thread its HPI latest video?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
