Old 01-27-2007, 09:29 PM   #46
what other engines will fit in the xxxnt just wanted to know
warrior is offline   Reply With Quote
Old 01-27-2007, 09:32 PM   #47
LOWGEARED's Avatar
I know this guy from rcu told me he has the OS 18 cv engine in his.. so I would say OS is and probably novarossi too.
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 01-27-2007, 09:37 PM   #48
good deal i'll look into that thanks
Old 01-27-2007, 09:38 PM   #49
LOWGEARED's Avatar
correction Any standard shaft,small block engine from .12 all the way to .18 will fit no problems...
Heard fantom is real fast...
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 01-27-2007, 09:40 PM   #50
more speed is what xxx needs
Old 01-27-2007, 09:50 PM   #51
LOWGEARED's Avatar
Try the drake engine
http://www.teamtrinity.com/shop/engi...lat122128.html
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 01-27-2007, 10:06 PM   #52
streetracer745's Avatar
Send a message via AIM to streetracer745
ok one, the jato isnt an onroad racer. the jato 3.3 is, but thats not even a race truck....... and the jato 2.5 has 2 speed, but put it on the track and tis just too much power. almost all race trucks can hold any standard small block. and lowgeared, the 7700 in a pede!!!! are you insane or just plain stupid?
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 01-27-2007, 10:11 PM   #53
and if you want real power and speed. lighten the truck up as much as you can and drop this into it. one of the best .18's out. very modified and very reliable. even in a drag you will probly run with a jato
http://www2.towerhobbies.com/cgi-bin...?&I=LXLNF9&P=7
Old 01-27-2007, 10:22 PM   #54
LOWGEARED's Avatar
I prefer both terms!!!!! insane mostly but stupid is a great one too!!!! C' mon man my pede would rock...I could upgrade to a 1/4 inche steel chasis to keep the nose down.
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 01-27-2007, 10:54 PM   #55
those are some very high dollor engines . i'll have to save my $$$$$$
Old 01-27-2007, 11:10 PM   #56
LOWGEARED's Avatar
That was my thought too! Next year for me!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 01-27-2007, 11:24 PM   #57
would the 3.3 fit ?
Old 01-27-2007, 11:43 PM   #58
LOWGEARED's Avatar
Well Im not sure cause when you upgrade from 2.5 to 3.3 for traxxas models you have to buy the upgrade kit with the engine!!!! but Ill say it is small block I believe and vertually all small blocks will pop right in. Somebody will jump me if I was to say yes!!! but Im almost 75% positive it will.. not sayin might have to buy some slight mod kit with it... Somebody will clear this up for sure..
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 01-28-2007, 09:21 AM   #59
well that depends on if the 2.5 will fit into it? the 3.3 has the same mounting holes as the 2.5. it can mount anywhere a 2.5 can as long as there is room. it is a direct bolt on for the revo2.5. the only thing i had to do to fit my 3.3 onto my revo was, well..... bolt it on
Old 01-28-2007, 09:23 AM   #60
and the kit to go from the 2.5 to the 3.3 is the same. i had to get one for my pede, but thats because i went from the pro.15 to the 2.5. they have the same mounting dememsions, only the 3.3's case is a little deeper and needs more room underneith
