Old 01-16-2007, 09:20 PM   #1
YokomoMR4BX's Avatar
Trader Rating: 3 (71%+)
Default Electric Motor Brushes?
If one brush is wearing unevenly. Is there something wrong with my motor? Should I replace the brushes? Thanks
YokomoMR4BX is offline   Reply With Quote
Old 01-16-2007, 10:13 PM   #2
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Coould be a spring issue. What motor are you running?
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 01-16-2007, 10:14 PM   #3
I'm running the Cobalt by Trinity 8x2 turn modified.
Old 01-16-2007, 10:16 PM   #4
Can I still use the same brushes if I change the springs? Even though they are uneven?
Old 01-16-2007, 11:57 PM   #5
Suspended
wingnutracing28's Avatar
your hood is out of line. there is a tool that aligns your brush hood. once it is inline you will not see one brush wore out diff. from the other. once you see that you need to change the brushes also. you will see better performance from your motors when the hoods are inline. it is not a spring issue, unless one is broke.
the way you align your hoods is remove the armature, insert the solid stock rod, slide the aligment tool through the hood where the brushes would go, the replace the hood with the solid stock through the middle of the alignment tool. while doing this the phillips screws in the hood should all be loose so you can align it all then retighten the phillips screws. then re-install the arm new brushes and your ready to go.
wingnutracing28 is offline   Reply With Quote
Old 01-17-2007, 01:06 AM   #6
Trader Rating: 96 (100%+)
Or, you could just dump all of your brushed motors and all of headaches, and buy a brushless setup.
K.Copeland is offline   Reply With Quote
Old 01-17-2007, 09:21 PM   #7
Team Tekin
Randy Pike's Avatar
The motor brushes are out of alignment. However simply sticking the alignment tool through the two is not the best way. Brushes "cock" in the hoods and this should be compensated for. I'd start with a set of new brushes AND springs. The first set of brushes on T motors usually are very soft and are inconsistent. Use their Lemans compound (silver) and purple springs on both sides. Timing should be set around 14 degrees or so if used in your "yok." What color are the brushes?
Randy Pike is offline   Reply With Quote
Old 01-17-2007, 10:15 PM   #8
Suspended
if you don't start with a properly alligned hood your just wasting money on $12 brushes and $3 springs. also putting a purple on both sides may or may not be the best for your electric motor. just slapping on any ole springs, you may lose torque,high end power, or low end. these motors are alot more capaible today, and you can't just stick anything on them. besides springs will not cause brushes to misalign or wear unevnly. also you may have run your motor to long between rebuilds and that could be why they are uneven. every ten to twelve runs of racing is a good gauge to rebuild your motor and with lemans brushes you can go 15 to 20.
Old 01-18-2007, 01:21 PM   #9
You're assuming that the brushes are wearing crooked and not just uneven as far as length goes. Purple's on both sides is a good starting point for that motor. I don't think he's quite into the full motor tuning yet judging by his question. The lemans brushes last well into the 40 run's area regardless of what class. Most of the big T's motors come set up this way. I was assuming he's running this motor in his yokomo judging by his name.
Randy P is offline   Reply With Quote
Old 01-18-2007, 02:00 PM   #10
mfishel's Avatar
If the springs are different tensions (as a lot of racers do in stock) then it certainly will cause uneven wear. I do recommend replacing springs every 5 or 6 brush replacements as they lose tension due to heat.
mfishel is offline   Reply With Quote
Old 01-18-2007, 04:30 PM   #11
Yes I was runing a MR-4BX but I'm about to start runinng a ZX-5. I bought some brushes from my LHS today and none of the brushes said Lemans on the packages. Where can I get some Lemans brushes? I did buy some brushes and they say "Spec Brushes" and the others Polarized Brushes-Mod. I know that the Specs are not for off road but are the Polarized Brushes? They're made by Trinity. I went ahead and changed the stock ones to the extras that can with the motor and I changed the springs. Also where can I get the alignment tool?
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
19 TURN MOTORS, STOCK MOTORS, 767 BRUSHES, F BRUSHES, 2 MOTOR CASES LOSIMANJRXS R/C Items: For Sale/Trade 47 10-21-2006 06:06 AM
Electric motor Brushes Lomaric R/C Items: Wanted to Buy 3 07-10-2006 07:50 PM
Electric Motor stuff Brushes, tools etc.. II Fast R/C Items: For Sale/Trade 4 09-19-2005 09:33 PM
Electric Motor Brushes coming loose... Kai_Fuller Electric On-Road 3 05-18-2004 03:32 AM
