Old 01-15-2007, 12:39 AM   #1
mxnut273's Avatar
Default why am i losing charging amps
PRODUCTS--CHECKPOINT RACE 3300 BATT.//LRP PULSAR 2 COMP.CHARGER//DYNAMITE 12V DC POWER SUPPLY
MY PROBLEM IS WHEN I AM CHARGING MY BATTS AT 6AMPS, WHEN THE BATTERIES GET TO ABOUT 2700,2800,2900 MY CHARGING AMPS START TO DROP TO ABOUT 4.5-5AMPS WHY IS THIS?????
THANKS
mxnut273 is offline   Reply With Quote
Old 02-06-2007, 06:18 PM   #2
Sneaky Pete's Avatar
Sounds like you are using flex charging instead of linear charging.
Sneaky Pete is offline   Reply With Quote
Old 02-06-2007, 06:54 PM   #3
AzBobby's Avatar
check out the settings on your charger and make sure that it is not set up to lower the amp rate when the pack is about to peak. however that drop in amps at the end gives you more run time and the 6 amp at the start helps your punch. kinda like the step charger from orion.
GO TECH
AzBobby is offline   Reply With Quote
Old 02-06-2007, 07:22 PM   #4
tfrahm's Avatar
Send a message via AIM to tfrahm
It might be that your power supply is weak...
If that is the case, as the battery approaches full charge, it takes more and more VOLTS from the charger/power supply combination to push the juice into the pack... Especially if the battery has some age on it, the IR will have gone up and the voltage it peaks at can climb -- if the power supply is weak, it will lose voltage when it is working hard...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 02-06-2007, 07:27 PM   #5
AzBobby's Avatar
right. also the first reply is a good thing to check in linear charge or flex charge mode. forgot the names of the profiles in that charger haven't used one in awhile.
GO TECH
Question on Hyperion/Lipos charging Amps? Paul Whalen Electric Off-Road 9 01-20-2008 06:46 PM
ESC 600 AMPS LINEAR 1200 AMPS MAX Windbreaker_guy R/C Items: For Sale/Trade 0 07-30-2007 03:49 AM
Charging amps? gofastrlbrown Electric On-Road 5 07-27-2006 11:24 AM
LD3...losing the backend. fishstix Nitro On-Road 5 03-16-2006 11:49 AM
