Old 01-13-2007, 01:21 PM   #1
Bighomedog11's Avatar
Send a message via AIM to Bighomedog11 Send a message via Yahoo to Bighomedog11
Default Battery Life?
Hey guys, I am wondering how many runs and how long should a battery last? I have a 7.2v 2000 mAh battery and it seems like it dieing faster and faster. I think the battery is dieing. So i am wondering how long and how many runs it should take before they are no good?
Bighomedog11 is offline   Reply With Quote
Old 01-13-2007, 05:52 PM   #2
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Depends on the battery pack. Usually you should get around 10 to 12 laps on a full charge.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 01-13-2007, 06:32 PM   #3
t-ray's Avatar
depends on the battery and how you charge it it could have a memory by now. also the new one last upwards of 1000 charges but thats a high number
t-ray is offline   Reply With Quote
Old 01-13-2007, 07:06 PM   #4
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
What charger are you using?
Cheers
Drift_Buggy is offline   Reply With Quote
Old 01-14-2007, 09:14 AM   #5
Well I am using the wall charger that came with the battery. I got the battery from Radio Shack.
Old 01-15-2007, 01:49 AM   #6
Wookiee528's Avatar
Batteries from radio shack are usually of poor quality. I would recommend getting a better battery from a hobby shop and also a better charger that has peak detection capabilities. I have a Superbrain977 that will charge any battery I will own, even my 1:1 car's battery, but I know not everybody wants to spend about $100 on a charger. So, just make sure you get a charger that has peak detection and some higher quality batteries and you will be good from then on.
Wookiee528 is offline   Reply With Quote
Old 01-15-2007, 03:10 AM   #7
And is the battery charging alot quicker?
Cheers
Old 01-15-2007, 03:12 AM   #8
Also, is the battery nicad? Do you store in discharged?
Cheers
Old 01-15-2007, 03:17 PM   #9
LOWGEARED's Avatar
I had a pair of tenergy 2100mah s and they were bunk !!!! They ran good for 5 or six charges and went downhill from there..... One pack gets hot after 15 min. charge time ..... But all my other packs are warm after 30 min. so you probably need to invest in good charger and 3300s and above nimh packs Nicads have bad memory effects..... You liiterally have to discharge them and put small rates of charge back into them for storing or theyll go bad!
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 01-15-2007, 03:20 PM   #10
Oh ok. I have a 2000 mAh Ni-Cd pack. I am gonna to get a better charger and better pack...And no i dont discharge. What is that? I might do it is that when u let the pack go all the way dead?
Old 02-04-2007, 10:02 AM   #11
Default 3000 Mah runtime?
How long will a 3000 Mah batt pack run in an RC10T4RS RTR (stock)
The T4RS has a 17 turn motor.
reillie is offline   Reply With Quote
Old 02-04-2007, 10:12 AM   #12
LOWGEARED's Avatar
Yes discharging is inoperable.... If you get to that point put it back on charge for 2 to 3 minutes and store it ,,, My batterys fried du to not discharging my packs cause of cell memory .... Try not to run one pack more than twice a day ... it sucks but they just cant handle it.
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 02-04-2007, 10:16 AM   #13
LOWGEARED's Avatar
10 to 15 minutes depending on the gearing and the way you drive it,,if your set high then less run time .. I still run cheap 1500 mah sportpacks from megatech and I get 8 or so WOT With a 12T mod geared 18 ... 86....
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 02-04-2007, 10:19 AM   #14
Default T4RS batt life question
The t4's gearing is stock (2.6:1). I dont know how to describe how i'll drive it but its for bashing, not racing. Thank you.
Old 02-04-2007, 10:28 AM   #15
LOWGEARED's Avatar
3700 are gonna be your best bet but if 3000 is what you can afford right now then they will be good enough better then my crappy batterys!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
new to rc...battery life vxv Electric Off-Road 4 07-05-2008 09:19 PM
Battery Life joe of loath Rookie Zone 6 02-01-2008 06:35 PM
battery life Hang_TiMe Rookie Zone 6 12-09-2007 12:02 AM
Battery life R/C Planet Electric Off-Road 1 01-29-2005 11:47 PM
Battery life ajg Electric On-Road 13 08-29-2003 10:39 PM
