Which way to make my throttle more sensative?
I have a few choices I guess, using a KO Helios EX-10. I want a more sensative throttle, so when I start to apply throttle it will go, and will help me have a better reaction to the track.
Anyway should I soften the trigger or should I adjust like TH Speed, Punch, etc in the controllers config?
turn up the th exp
make sure its the exp and not the th on the side of the radio. the on one the side only turn it up just a little to make your car coast a little better. if you go to high the car will go bye its self.
its called throttle curve on the helios. turn it up with the + button to make it more sensitive.
You can also increase throttle punch which will increase the sensitivity for the first 10% of the throttle triggers movement.
