XXX 4 SETUP What works ??????????? >
Old 03-06-2003, 01:48 PM
Default XXX 4 SETUP What works ???????????
Will I went and bought the buggy. I'm looking for some ideas on set up on it. I'm going to be racing it at Trackside in MIllwauke WI.
I will be running a mod class. Is the set up right out of the box the ticket? Waht i'm looking for are shock oil wts. Spring to use. Ride hgts. Any other info would also be great help also.Thanks for all and any help. What camber works well.
Track condition --- Hard packed damp smooth. GREAT TRACK!
Fatman is offline
Old 03-07-2003, 04:50 AM
JohnB's Avatar
Hello. I've been running mine since they came out and have tried about every setup out there and some other wild stuff. After all that, I end up racing close to the standard setup. This seems to best for me.
I think the only changes I have now are 1* rear hubs. I added BB to the stearing, that tightens it up a little. I've ran a sway bar a little bit, it can help in some situations. I just use the sway bar for my XXX buggy.
For ride height run the rear with arms level.
Front ride height is set so it's just a little lower than the rear, usually about bones level. On the indoor clay track I could run the car lower and not have problems bottoming out to bad, unless I overjumped something then it would slap pretty hard, but it cornered great.
take care
john
JohnB is offline
