Old 01-08-2007, 11:25 PM   #1
Default Rustler XL5 issue
Hey guys i just got my new Rustler XL5 today. So naturally i couldnt wait to test it out. It worked good at first after i did some tweaking with the steering and throttle trim. After about 5 mins i realized my reverse stopped working. I took it inside disconnected then reconnected everything and reverse worked then soon after didnt work. I know theres all these profiles but i dont see why it would jump to another profile in the middle of my driving?? It just didnt make sense cause at times it would come back then go away again. Any ideas?? Like i said its brand new so i really doubt i ruined anything yet.
1 more thing, whats up with the battery packs barely fitting in there? My friend's pack actually did'nt fit unless we forced it and probably would've cut off the wires.
Thanks guys.
te04rx8 is offline   Reply With Quote
Old 01-09-2007, 03:31 PM   #2
LOWGEARED's Avatar
Try reseting the programming its in the manual I had a problem like tht with my XL-5 stampede it works fine now!
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 01-09-2007, 04:29 PM   #3
Do you mean manually setting Profile 1 through the esc? ? I though its supposed to reset to that setting as a default when the battery is disconnected then reconnected.
Anyway thanks ill give it a try.
Old 01-09-2007, 04:50 PM   #4
LOWGEARED's Avatar
1. disconnect motor lead 2. connect Battery 3. turn on radio set all trims to 0 4. turn on esc hold button till first red appears let off as soon as youi see it . 5. led will blink red once pull throttle all way back hold it till blinks red twice then put in brake position hold it till it turns green then your ready! hook back up and should be fine.
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 01-09-2007, 08:00 PM   #5
Thanks for the help i appreciate it..
Old 01-10-2007, 12:41 PM   #6
LOWGEARED's Avatar
did that fix the problem?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Rustler MM 5700 or VXL Rustler??? RCRat Electric Off-Road 4 08-14-2008 04:03 AM
Rustler & Rustler VXL Transmission.. andy85 Electric Off-Road 3 06-13-2008 05:52 PM
Rustler has an issue GBdaMan Rookie Zone 2 06-13-2007 01:58 AM
DPD issue Racingfreak6 Electric On-Road 5 01-01-2007 09:56 AM
OS .12 5p issue Black_Widow Nitro On-Road 4 12-18-2006 10:19 AM
