Old 01-08-2007, 07:48 PM   #1
Dougg's Avatar
Default Bullet proofing a xx4
I'm buying a xx4 in a couple of days, Please tell me the areas that need to be made stronger and how. As of now I don't wish to convert to an X-5. Possibly later. I will be running 4wheel mod. I have a xxx4 now, but I'm converting over. I've posted on a couple of forums to get as many people to see this.
Doug
MBX7r, MBX7R Eco, 22-4 2.0
Dougg is offline   Reply With Quote
Old 01-08-2007, 08:17 PM   #2
PHIL700XCSP's Avatar
Save some money and buy an aluminum bulkhead as they are very prone to breaking.
PHIL700XCSP is offline   Reply With Quote
Old 01-08-2007, 08:42 PM   #3
Trader Rating: 28 (100%+)
Lots of info here: 4wd Forums
Aluminum bulkhead shouldn't be necessary if you've got the white 10* bulkhead and use the associated b2/b3 brace across the front of the hinge pins.
jbrow1 is offline   Reply With Quote
Old 01-08-2007, 08:42 PM   #4
Trader Rating: 70 (100%+)
Send a message via AIM to TexRacer
Doug,
When you come to Dallas you will see what guys have done to really help.
1-Put a B2,B3 front brace on it.Takes a lil cutting but not much at all.CURES the bulkhead issue.
2-Look on 4wdrc.com and buy Chazz's screws for the front spindles.They DO help.
3-Get the Penquin Shock Tower Kit.It does help.
4-Being you really ONLY use the 1st 2 holes on the rear shock tower on the TOP...Cut the other one's off and round off the edge.
The MORE that hangs off the easier it is to break.
When you move down here bring me a Dragon R/C B4 rear bulkhead with the extra camber hole.
Les
*****Look me up on Ebay. I will have alot of stuff going up as 7/7/2016. User name is Dalracer.**** This is going to be a BIG ONE!!!!!!
Just wanted to say Thanks to RcTech for all these years of Great Information.
TexRacer is offline   Reply With Quote
Old 01-08-2007, 09:12 PM   #5
BuggyKing's Avatar
Trader Rating: 17 (100%+)
I run a Associated B2 front brace. I run CVd's in the front.
Also instead of running the blue front belt. Go with a green belt. Run longer ball studs in the front Caster hubs. The bellcrank steering is on backorder so be careful and don't put the car into the wall. Run the clicker on softest setting. And lock out the slipper as well.
Try and get a Trinity motor clamp as too the grahite one will break, and you will start chewing spur gears.
I have guy who made an aluminum motor clamp.
Ron,
[email protected]
He sells them for $25.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 01-08-2007, 10:33 PM   #6
Dougg's Avatar
Originally Posted by TexRacer
Doug,
Les
That bulkhead is very popular here. I didn't know anybody knows about Dragon outside of the MHOR track. The shock tower is the only thing I wasn't aware of. Who carries it? I allready have the A-Main carriers. I put them on my xxx4, havn't brokin anyfront end part yet. Belive me. I've hit some things very hard that should have caused a great deal of damage. Looking forward to getting down there. I've ben monaturing Mike's forum. You run 3 classes of stock buggy? let me know about that please.
Doug
Old 01-08-2007, 10:57 PM   #7
sport10's Avatar
The B3 front brace and the Kingpin mod at 4wdrc.com is all that is needed to make the buggy pretty durable. Do keep a set of carriers in your spare parts because they do break every now and again but not enough to justify aluminum carriers(adds weight). Upgrading to an X-5 will give you a stronger chassis and a more efficient single belt drivetrain.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 01-09-2007, 12:44 AM   #8
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Is that all that is fragile on the XX4
Cheers
Drift_Buggy is offline   Reply With Quote
Old 01-09-2007, 04:55 AM   #9
Buck Nasty's Avatar
penquin shock tower kit
http://www.penguinrc.com/welcome.shtml
I think, therefore I'm single. Buck Nasty
Buck Nasty is offline   Reply With Quote
Old 01-09-2007, 06:51 AM   #10
Default xx-4
anybody know where I can get one of those B2/B3 braces? thanks chris
garrettsdad is offline   Reply With Quote
Old 01-09-2007, 06:56 AM   #11
Buck Nasty's Avatar
AE part #9120.
Old 01-09-2007, 07:20 AM   #12
Default xx-4
ya i knew the part number, just can't find the part.....Any help with where to find one of these rare jewels? thanks chris
Old 01-09-2007, 08:46 AM   #13
sport10's Avatar
Cheers
The front arms are the most fragile thing. Using either the kingpin mods or a set of crashback arms solves this. The front bulkhead will not break but the holes for the arms will elongate if you do not have the B3 brace. Also, make sure the metal brace for the rear is on the car. It comes with the kit.
Associated B44
Associated B6
Associated TC7.1
Old 01-09-2007, 08:56 AM   #14
STEALTH's Avatar
They seem quite hard to come by as of late... Tower, Horizon, and Stormer are all out of them. If you don't mind getting one from England... here is one on E-Bay right now... and it seems to be the only one on there too!
Best of Luck!
http://cgi.ebay.com/TEAM-ASSOCIATED-...QQcmdZViewItem
STEALTH is offline   Reply With Quote
Old 01-09-2007, 12:25 PM   #15
tyreman's Avatar
Why bother with a associated front brace when the XXXBK2/XXXcr front brace fits fine
Schumacher, Speed Passion, Speed Power, Custom Blitz, RudeBits, Sanwa, Racer, Ripmax, Muchmore Racing, B-Fast RC performance parts, Nuclear-RC
tyreman is offline   Reply With Quote
Poor Man's buggy diff bullet proofing TeeKuang Malaysian R/C Racers 12 02-10-2008 10:11 PM
LRP Bullet AI Dannn R/C Items: For Sale/Trade 4 09-05-2007 08:38 PM
Bash/Crash proofing for rookies customride Rookie Zone 12 04-21-2007 03:12 AM
LRP AI Bullet ESC Cubsfan24 R/C Items: For Sale/Trade 5 04-12-2005 09:40 PM
FSR Bullet Pro Macky R/C Items: For Sale/Trade 6 04-25-2002 09:38 PM
