Old 01-09-2007, 01:58 PM   #16
Try P&T hobbies, I know they have several of the braces on their wall. Check their website http://www.pnthobby.com/ and give them a call.
br93lx is offline   Reply With Quote
Old 01-09-2007, 02:12 PM   #17
Dirt-Racer's Avatar
Send a message via MSN to Dirt-Racer
Originally Posted by tyreman
Why bother with a associated front brace when the XXXBK2/XXXcr front brace fits fine
Cuz he's a noobie and an idiot. Told someone to go wank off ebay and here he is now, not only suggesting to go on ebay but ebay.uk? hahaha also he dont know shit.
Dirt-Racer is offline   Reply With Quote
Old 01-09-2007, 02:26 PM   #18
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
Originally Posted by garrettsdad
ya i knew the part number, just can't find the part.....Any help with where to find one of these rare jewels? thanks chris
$1.45 at tower hobbies but isn't due till late january
http://www2.towerhobbies.com/cgi-bin...?&I=LX3173&P=7
Cheers
Drift_Buggy is offline   Reply With Quote
Old 01-09-2007, 02:28 PM   #19
got an associated one today at the LHS thanks for the help fellas.....I am new with my 4 wheeler (X-5) but i am loving it so far!
garrettsdad is offline   Reply With Quote
Old 01-09-2007, 02:43 PM   #20
Trader Rating: 28 (100%+)
Originally Posted by TexRacer
Doug,
When you come to Dallas you will see what guys have done to really help.
1-Put a B2,B3 front brace on it.Takes a lil cutting but not much at all.CURES the bulkhead issue.
2-Look on 4wdrc.com and buy Chazz's screws for the front spindles.They DO help.
3-Get the Penquin Shock Tower Kit.It does help.
4-Being you really ONLY use the 1st 2 holes on the rear shock tower on the TOP...Cut the other one's off and round off the edge.
The MORE that hangs off the easier it is to break.
When you move down here bring me a Dragon R/C B4 rear bulkhead with the extra camber hole.
Les
What is the penquin shock tower kit? Good tip about cutting the rear shock tower. Think I'll give that a try myself.
jbrow1 is offline   Reply With Quote
Old 01-09-2007, 09:06 PM   #21
The Penguin kit is not shock towers but are an add on to the cars shock towers. All they are are thin carbon fiber plates that mount in front and behind the towers to add strength. They do work, since putting them on I have never broken a tower since. This doesn't mean that they are unbreakable however. They just make it less likely to break a tower after you mount them. Go to the Penguin site, they have pics of these braces there.
WailinOnYa is offline   Reply With Quote
Old 01-09-2007, 09:47 PM   #22
Dougg's Avatar
I got my xx4 tonight. That front brace I picked up at Hobytown in wesminster,Colo. They had 4 or 5 on the shelf. I didn't know they were hard to get. Why won't the BK2 brace not work? I will try the cutting of the shock tower thing. I heard that if you fill the most outside brace on the front A- arm with epoxy, it will help the strenth. Or is that someone blowing hot air?
Doug
MBX7r, MBX7R Eco, 22-4 2.0
Dougg is offline   Reply With Quote
Old 01-10-2007, 06:49 AM   #23
The losi brace is thicker metal, you already have to shave some of the bulkhead to get the assoc. brace in place.....there's not alot of material left. Have fun with the wheeler!
Old 01-10-2007, 08:33 AM   #24
sport10's Avatar
I have been running the X-5 for quite a while (same suspension as XX4) and never had a problem with the shocktower breaking at the shock mounts. The rear wing absorbs most of the punishment. So if you want to cut of the top two holes go ahead but I would rather keep the tuning capability since I have used those holes on different tracks. There are instructions on how to install the B3 brace at 4wdrc.com under the tech section if you need them.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 01-10-2007, 08:35 AM   #25
sport10's Avatar
It greatly increases the strength of that area. Once I did that I never broke the arm in that section again.
Associated B44
Associated B6
Associated TC7.1
Old 01-12-2007, 09:37 PM   #26
Dougg's Avatar
well, i tried it at the track today. this thing drives 10 times better than my xxx4. i'm glad i bought this thing.
Doug
Old 01-13-2007, 06:28 AM   #27
Buck Nasty's Avatar
You can also go to www.4wdrc.com and look in there store. You will find the hub carrier screw kit there. That will do what the epoxy will do and looks trick.
I don't like the idea of cutting down your rear shock tower. I have used the outside hole with soft springs and got good results. I like the penquin shock tower kit. I just mounted it tonight and it looks like it is just enough to save you in most cases. I'll post a pick as soon as my camra battery's peak.
I think, therefore I'm single. Buck Nasty
Buck Nasty is offline   Reply With Quote
Old 01-13-2007, 07:05 AM   #28
Buck Nasty's Avatar
Default The Penguin kit
Here ya go...........
Bullet proofing a xx4-shock-tower-1.jpg   Bullet proofing a xx4-shock-tower-2.jpg   Bullet proofing a xx4-shock-tower-3.jpg
Old 01-15-2007, 07:45 PM   #29
Dougg's Avatar
sat. was the first time my xx4 hit the track. the best i could do with my xxx4 was 19 laps. the first time the xx4 hit the track i did 19 laps, and i wasn't comfertable with the buggy yet. 2nd time another 19 lapper, third heat was a 20. then the main was a 21(5.09)!!!! i'm still not fully comfertable with the car yet. when i left sat night, i knew i made the right desision. i finished 2nd by .13 seconds. i'm big time impressed with the xx4. thanks for the imput that you guys gave to me.
Doug
Old 01-16-2007, 05:07 AM   #30
frankiecmgt's Avatar
Trader Rating: 77 (100%+)
BUCK NASTY...
COULD YOU POST SOME FULL PICS OF YOUR XX-4. I AM INTERESTED IN HOW YOU MOUNTED THE STEERING SERVO.... . THANKS FRANKIE...
I AM A BELIEVER IN THE R/C TECH UN-WRITTEN RULE " HE WHO HAS THE LOWER FEEDBACK SHIP'S FIRST "......
frankiecmgt is offline   Reply With Quote
Poor Man's buggy diff bullet proofing TeeKuang Malaysian R/C Racers 12 02-10-2008 10:11 PM
LRP Bullet AI Dannn R/C Items: For Sale/Trade 4 09-05-2007 08:38 PM
Bash/Crash proofing for rookies customride Rookie Zone 12 04-21-2007 03:12 AM
LRP AI Bullet ESC Cubsfan24 R/C Items: For Sale/Trade 5 04-12-2005 09:40 PM
FSR Bullet Pro Macky R/C Items: For Sale/Trade 6 04-25-2002 09:38 PM
