Calcium grease for R/C car differential
Can calcium grease be used for metal differential gears? Is it safe for the plastic housing?
It should be fine, but silicone grease will give you more of a limited-slip action. Or if the differential has O-ring seals, silicone oils in a wide range of viscosities are available to fine-tune the differential's limited-slip action. You probably don't want a fully open differential, like you'd get with any kind of petroleum grease, if you care about performance at all.
what? There are still gears in the differential. The ring and pinion gears need to be lubricated
