Old 01-07-2007, 10:43 AM   #1
streetracer745's Avatar
Send a message via AIM to streetracer745
Default need help soldering a reedy neo-one motor. please help
i have a reedy neo-one motor in my race truck right now. i want to put it into my dark impact. the can fits, but the wires get in the wway because they stick out over the can. unfortinutely my soldering iron doesnt get hot enough to melt the existing solder on the tabs to remove the wires. is it safe to cut the wires right next to the tabs and resolder them onto the oposite side onto the existing solder?
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 01-07-2007, 11:36 AM   #2
Rysuleod's Avatar
If you can afford brushless then you can afford a more powerful soldering iron. I would not do what you are proposing to do. It's just a wire in a little hole. Make sure the iron is touching the hole where the wire is threaded. I 40W cheapo soldering iron should be able to handle that.
Rysuleod is offline   Reply With Quote
Old 01-07-2007, 11:40 AM   #3
i put basically all the cash i have onto this motor. between gas and food i cant afford to get anything right now. but if its not safe to do what i asked and put the motor in my buggy right now i guess i wont.
Old 01-07-2007, 11:54 AM   #4
CNC Racing's Avatar
Trader Rating: 23 (100%+)
I've done exactly what your proposing to my Neo motor in my T4. You MUST use at least a 40 watt iron (I use a Weller) - this will un-solder the wires in just a few seconds. To re-solder to the opposite side of the tabs - first, tin the tabs using a small amount of flux and solder. Then re-solder the wires to the tabs, again should take just a few seconds using a the 40 watt iron. You don't want to overheat the tabs by keeping the iron on the tabs too long, which is why you need to use the 40 watt iron to get the job done quick.
CNC Racing is offline   Reply With Quote
Old 01-07-2007, 11:59 AM   #5
Rysuleod's Avatar
If you race borrow someone else's iron at the track then. It's not that you can't do what you are proposing. It might work, and be safe but why do it?
Clipping thru 12-14 gauge wire with solder inside it (because you'd have to cut against the tab almost) would be very difficult.
Old 01-07-2007, 12:12 PM   #6
Rysuleod's Avatar
Lol you didn't like our answers so you're asking Aaron Waldron? It's probably safe if you really want to do it but it's not the right thing to do to a $250 brushless ESC set.
Old 01-07-2007, 12:37 PM   #7
hey man im just trying to get answers. i cant afford a new soldering iron. ill try getting one from someone at the track.
Old 01-07-2007, 12:38 PM   #8
and i asked right after your answer. and its not that i dont liek your answer. i just want to check with different people
Old 01-07-2007, 12:50 PM   #9
mfishel's Avatar
You can get a 40w Weller iron for $20 at your LHS. Come on.
mfishel is offline   Reply With Quote
Old 01-07-2007, 01:51 PM   #10
if its gonna be cheap then ill get one. but i dont have much money to blow right now
Old 01-07-2007, 08:33 PM   #11
AndyMoore's Avatar
Trader Rating: 54 (100%+)
Send a message via AIM to AndyMoore
Not to flame but....
In order of importance,
1. Tools
2. Iron
3. Brushless setup
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 01-07-2007, 08:39 PM   #12
well i have one. but its only like 30 watts or so. not hot enough for the solder on the tabs. im getting a new one. thats my next investment.
Old 01-07-2007, 10:53 PM   #13
AndyMoore's Avatar
I know home depot as well as most LHS sell the weller 40 watt for 15 or 20. If youre that tight on cash borrow an iron.
Old 01-07-2007, 10:55 PM   #14
i can afford 20 or so. thats not bad at all.
Old 01-08-2007, 01:18 AM   #15
jgroenhof's Avatar
Default Don't forget
You have to tin your iron.
If you melt a bit of solder onto your iron, it will transfer the heat into the old solder much faster. I have forgotten to do this from time to time, and it seems like my iron wouldn't melt wax. Then tin it and it's fine.
Or just borrow someone's. But don't for get to tin it.
Late!
Johnny G
OCRC.
jgroenhof is offline   Reply With Quote
FS: MTRONIKS GENESIS TRUCK B/L ESC, FEIGAO 380C-6L MOTOR & REEDY NEO-ONE 4 STAR MOTOR davidrrr R/C Items: For Sale/Trade 5 08-16-2008 03:32 PM
Soldering motor wires on mm esc aggieboy Radio and Electronics 6 03-04-2008 05:13 AM
soldering reedy neo-one motor help? streetracer745 Electric On-Road 11 01-06-2007 08:58 PM
need help on soldering a motor please volumefader Rookie Zone 4 06-04-2006 04:01 AM
Positive and negative motor soldering? adr3naline fix Electric On-Road 11 09-04-2005 08:06 AM
