Elect. Rustler with Reedy 19t ... WHat gearing? >
Old 01-02-2007, 02:31 PM
shaggys40oz's Avatar
Default Elect. Rustler with Reedy 19t ... WHat gearing?
Hey all, My 12yr old nephew just got a Rustler for xmas. We put in a new Reedy 19t motor and used the stock pinionand spur gear. The car has weak top speed, good torque, but the motor gets extreemly hot. Can anyone tell me what a good gearing combo i could use. It is strictly a basher truck.
shaggys40oz is offline
Old 01-02-2007, 02:45 PM
Vato Loco's Avatar
I have a Rusty and Reedy 19T! The quad mag is a mostly torq motor! On a hard packed surface with light tires I run 20/84 but for everything else 18/87! Lighter tires will help to get the temps down and speeds up too!
Vato Loco is offline
Old 01-03-2007, 02:47 PM
Thanks Vato!! Do you have any idea of what kind of speeds can I expect?
ALso when you pick up your truck and the rear supension is fully extended do your rear wheels have more resistance (almost a binding feel) when turning them. once i compress the shocks and the wheels come up a bit and the drive shafts get a little more horizontal then the wheels free up and rotate perfectly. any thoughts?
Old 01-03-2007, 03:25 PM
amain's Avatar
i dont know if the rustys ahve them but you can set the droop to stop that from hapning. if not its really not a problem. also make sure that the esc can handel a 19t motor. it may work fin now but once u get stuck and pin it it will blow the esc if its not able to handle that low of a turn.
amain is offline
Old 01-06-2007, 10:00 PM
I quickly looked for a droop adjustment and didn't find one, but if I could then that probably would fix my problem. Thanks everyone for the replies .... and keep em comin if you have any other thought out there
Old 01-06-2007, 10:28 PM
Bighomedog11's Avatar
Is that 19t fast? I have a xtm X-C I might put a 19t in. Also what battery are u using what ist he mAh? Just wondering because i might get a 19t motor or maybe lower
Bighomedog11 is offline
Old 01-06-2007, 11:06 PM
My nephew's is not fast at it's current set up .... but hopefully changing the gearing will help. If i were you I would get the fastest motor \you can afford .... with me I always wish i could go a little bit faster ... no matter what I have
