Engine troubles
Old 03-02-2003, 09:02 PM
Unhappy Engine troubles
I got my car finally... It is an OS CZ-R .12 engine. I am running Blue Thunder 20% fuel through it. Okay, When i start it and let it warm up , it doesnt idle like I want it to. It idles too high. When I try idling it down, it just ends up richening it and flooding it out. I have no idea what to do.
PLEASE HELP ME!!!
Reid
I know the engine looks like an airplane engine... but its not...
Losi-XX is offline
Old 03-03-2003, 01:31 PM
corvettecrazy's Avatar
i'm not an expert or anything but if it was mine I would clean it first.
corvettecrazy is offline
Old 03-04-2003, 07:19 AM
Turbo9000's Avatar
Wow... I havent seen a CZ for a while.
Is there a low speed adj needle?
Turbo9000 is offline
Old 03-04-2003, 03:47 PM
Well the engine is pretty clean because that is an older pic. And yes i do believe there is a low speed needle. but im no expert im just a nitro noob
Losi-XX is offline
Old 03-05-2003, 03:13 PM
It could be to rich, If you turn the idle down it should be getting less fuel (less air to pull the fuel into the engine. Set your high speed first, then the low speed. The idle should be the last thing you set on the engine.
nitro dipstick is offline
