Old 12-26-2006, 12:34 AM   #1
ScottyP's Avatar
Default XXX4 chassis mould
Does anyone know if the XXX4 chassis mould nas been changed at any time to accomodate the newer, larger cells? Hope it has, otherwise its out with the Dremel to get a better fit!
Scotty P.
ScottyP is offline   Reply With Quote
Old 12-26-2006, 12:54 AM   #2
Drift_Buggy's Avatar
Trader Rating: 21 (100%+)
No, not that I know of
Cheers
Drift_Buggy is offline   Reply With Quote
Old 12-26-2006, 05:27 AM   #3
LOSI BOY-MF2's Avatar
Trader Rating: 80 (100%+)
Im running the xxx4 with the new IB4200 and I had to dremel it out.
LOSI BOY-MF2 is offline   Reply With Quote
Old 12-26-2006, 08:13 AM   #4
Trader Rating: 24 (100%+)
Default Cell Slots
I wish I had a version without slots -- for using LiPos. Does anyone else use LiPos in the xxx4? I need to mill down all the tabs to get a rectangulr pack to sit nice, then the slots aren't too usefull except if you want to run strapping tape maybe.
BobWoodhouse is offline   Reply With Quote
Old 12-26-2006, 09:15 AM   #5
I've been looking for a good way to deal with this problem too. Can't say that I'd really want to buy a new chassis just to get a better fit.
I currently have my 4200's installed as a saddle pack and that seems to work OK in the stock chassis without any grinding. I'd definitely prefer to have all 6 side-by-side, but it looks like a lot of work to get there.
paulsrvd is offline   Reply With Quote
Old 12-26-2006, 09:27 AM   #6
BuggyKing's Avatar
Trader Rating: 17 (100%+)
It is the same chassis. You shouldn't have any issues.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 12-26-2006, 10:46 AM   #7
SlobbaTech's Avatar
The GP3300's are the "last" cells we used I think hat fit into the XXX-4 OK, the 4200's for sure, then I'm prety sure the 3600/3800 IB's you also had to dremel the chassis to allow 6 cells one after on another to fit into the car.
Hot Bodies, HPI, Novak Electronics, JR Propo, Lunsford, Skipgear.com, Planet R/C, Vinyl Graphics Unlimited, JConcepts, B-Mods Racing, CRCRC, King's R/C Raceway, Avid R/C, GMK Supply, & Pacific Coast Hobbies.
SlobbaTech is offline   Reply With Quote
Old 12-28-2006, 09:20 PM   #8
For the Lipos just turn the strap over and grind off the little tab. For the 4200 / 4300 's you have two options that I know of. Dremel the battery strap or use the plastic strap rather than the graphite one. I use the plastic one and it has just enough flex to strap it over the pack and hold them in tight.
kzacher is offline   Reply With Quote
Old 12-28-2006, 11:19 PM   #9
Platinum_Racing's Avatar
Send a message via MSN to Platinum_Racing
Looks like you're gonna be hitting the Dremel pretty soon then.
Platinum_Racing is offline   Reply With Quote
Old 12-29-2006, 02:17 AM   #10
Trader Rating: 96 (100%+)
Are the 4200's both longer and wider than 3300's ?
K.Copeland is offline   Reply With Quote
Old 12-29-2006, 10:31 AM   #11
SlobbaTech's Avatar
The length (if they are longer) doesn't really matter on the xxx-4, but it's cell radius does. The cells are just a little bigger, so if you had a 2 cell pack they'd fit fine where a 6 cell pack doesn't as that "little" difference in cell radium accumulates into a "healthy" sized difference by the time you get the cell #6 slot on the car. So you will be dremeling more and more as you move on to the next chassis slot and may not need to dremel any if much at all on the first 2-4 slots.
Old 12-30-2006, 01:50 AM   #12
RussB's Avatar
Send a message via MSN to RussB
i've run IB3600's and 3800's in my xxx4 with no problems.
RussB is offline   Reply With Quote
cutting the body from the mould for FT B4 - HELP !!! simba Electric Off-Road 8 09-12-2007 09:50 PM
cutting the body from the mould - HELP !!! simba Australian Racing 7 09-11-2007 11:54 PM
xxx4 chassis. maxxman101 Electric Off-Road 2 11-30-2006 03:44 AM
WTB XXX4 MAIN CHASSIS BIG DADDY8 R/C Items: Wanted to Buy 2 10-16-2006 03:14 PM
wtb new or lightly used XXX4 chassis tinbndr R/C Items: Wanted to Buy 2 02-20-2006 07:08 AM
