Old 12-17-2006, 09:31 PM   #1
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Default XX4 with front CVD's!
Hey Guys,
I am going to run CVD's in the front. Can I use my current bearings or do I have to change. Thanks guys,
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 12-18-2006, 02:42 AM   #2
They used to make two different CVD Kits, one which used the original
bearings and one that used the more common rear axle size bearings. Personally I would opt for the smaller axles/bigger bearings and go for the set that uses the rear axle bearings. They hold up much better to abuse than the kits original bearings. The only real difference in the kits are the axle diameters which allow you to use one bearing size versus the other. From what I have seen and personally ran my self, most if not all go to the rear axle bearing size when switching to front CVD's, for durability reasons, also helps with less spare bearings due to the fact that the rear hubs will use the same bearings.
WailinOnYa is offline   Reply With Quote
Old 12-18-2006, 11:27 AM   #3
BuggyKing's Avatar
thank you for the help.
RIP Mike M
Old 01-23-2007, 09:18 PM   #4
which cvds fit the front of xx4? are they the same as the rear? or the same as the xxx4 front cvd's?
4times is offline   Reply With Quote
Old 01-23-2007, 10:43 PM   #5
Trader Rating: 54 (100%+)
The xxx4 front CVD's. Buy the kit and comes with everything but the bearings, and like was already mentioned, it takes the standard bearing like the rear uses (3/16" x 3/8"). Part number is LOSA9967
jsmax is offline   Reply With Quote
Old 01-24-2007, 10:03 AM   #6
thanks
****Revo****Integy Alloy Front, rear and middle-front skid plate set in silver. jf45 R/C Items: For Sale/Trade 6 05-07-2008 12:04 PM
FS/FT RC10B4RS BRAND NEW IN THE BOX+LUNDSFORD TB'S,ALUMINUM FRONT BULKHEAD,AND CVD'S chadlow21 R/C Items: For Sale/Trade 1 12-13-2007 05:25 PM
CVD's - How do you maintain your CVD's? kn7671 Electric On-Road 13 11-27-2007 07:23 AM
MBX5 Front Shock Tower or MBX5R Front Shocks skelly1344 R/C Items: Wanted to Buy 2 08-09-2007 06:54 PM
Alum Tamiya TA04 Front Steering Block / Front Upright Alvin Singapore R/C Racers 2 02-04-2002 07:50 PM
