Old 12-11-2006, 08:54 AM   #1
Hawk6's Avatar
Trader Rating: 50 (100%+)
Default Brushless Carpet Stadium Truck Problems - HELP
My son and I race Novak Super Sport + brushless systems in stadium trucks on an indoor carpet track with jumps.
In 6 race weekends, we've burned up both systems, and now one of the remanufacturing units we just got back from Novak is starting to act up.
Are we doing something wrong?
We're geared at 12.28:1 (87/17 x 2.4) which is where we are supposed to be.
The last system that blew up raced fine in the first qualifier. For the second qualifier, it just didn't start. If I'd spin the spur gear a bit, that seemed to help. I looked at it afterwords, and after hitting the throttle and the motor not spinning, the ESC would have blinking blue and green LEDs. I removed the pinion completely (to make sure the trucks drivetrain wasn't binding up causing the motor to fail) and the motor still didn't work.
This weekend, my son's freshly refurbished ESC and motor did the same thing. At the start of the race he had no motor. Someone bumped into his truck and got it rolling, then it took off.
The only thing I can think of is maybe our slipper clutches are too tight so when we're landing off the jumps, the back wheels hit and stop spinning for an instant, the motor stops for an instant and is being damaged somehow.
Anyone have any ideas????
Thanks.
Hawk6 is offline   Reply With Quote
Old 12-11-2006, 11:36 AM   #2
RAZ49's Avatar
It could be the slippers being too tight or gear mesh too tight or over geared a little. Did you ever check the motor temps? They should not exceed 175 F. I've had the SS4300 and now a refurbished SS5800 and never a problem so I can't help but think it's something in your set-ups.
RAZ49 is offline   Reply With Quote
Old 12-11-2006, 11:42 AM   #3
Hawk6's Avatar
Thanks for the reply.
It happens at the start of a race, after the truck has been sitting for an hour.
And like I said, I even took the pinion off (so there was zero drivetrain drag) and it still did it. This was the night after a race (so the motor was cold), just trying to figure out the problem.
After a 5 minute race, the motors may be warm, but not anything I would call hot, I'm sure below 120 deg, probably less.
So, my theory is we're abusing the motors somehow by landing jumps with slipper clutches set too tight and sort of "dead spotting" the brushless motors. Can that be possible.
I called Novak last week and he made it sound like the Super Sport+ ESCs may not be perfectly reliable. He said I could get a GTB for $30 more if I send in a SS+ that has failed repeatedly.
Thanks again.
Old 12-11-2006, 11:48 AM   #4
Davidka's Avatar
Trader Rating: 77 (100%+)
With the Super Sport systems motor temp is generally not an issue. The Speed control typically struggle a little to keep up. You still shouldn't be seeing anything other than thermal shutdowns if the speed control is overloading. I assume that you are running on Ozite carpet or something similar so static electricity damage shouldn't be an issue.
I would recomend the GTB upgrade option. For $30 more that's a no brainer. You can then put in a stronger motor down the road if you like.
Old 12-11-2006, 11:56 AM   #5
Hawk6's Avatar
Thanks. Yea Ozite or something similar.
A bunch of other people are running brushless with no apparent problems. I'll just need to check around and see what others are doing or not doing compared to me.
It was a real bummer to get my son's new (remanufactured) SS+ and 13.5 back from Novak Friday, run it Saturday, and have it not start one of the qualifiers until he got "bump drafted". It worked fine the other 2 qualifiers and main. Hopefully it was just a fluke (but I doubt it).
Thanks again.
Old 12-11-2006, 01:17 PM   #6
Davidka's Avatar
Oh, if they work but have a hard time getting started then it almost has to be someting to do with the position sensor (the bundle of thin wires from motor to speed control). The sensored design of the Novak stuff is specifically designed to fix that problem so if you are having start up problems then that's almost certainly what it is.
Old 12-11-2006, 02:10 PM   #7
RCGaryK's Avatar
Scott, the other thing you may want to try to help keep things cooler is install the Sintered rotor and upgraded endbell.
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 12-11-2006, 02:30 PM   #8
Hawk6's Avatar
Thanks Gary, but I don't think it's an overheating problem. The motors are never hot to the touch.
We race on Saturday, and on Sunday night - 24 hours after we last raced - I hooked up a battery, removed the pinion gear (so no drivetrain drag), squeezed the trigger, and nothing.
It seems like 2 out of three times, if I just rotate the spur gear a bit, and hit the trigger again, then the motor will take off just fine.
So, it appears like the motor has a "dead spot", but I don't know if that is even physically possible with a brushless motor. Maybe it is a sensor problem.
Anyway, I'm getting tired of sending brushless systems back to Novak for replacements.
Keep those ideas coming.
Thanks.
Old 12-11-2006, 11:11 PM   #9
WheelNut's Avatar
Send a message via MSN to WheelNut
Definately a sensor problem. Did you send in the motor with the ESC? If not I would do that.
•Brad Comis
WheelNut is offline   Reply With Quote
RPM 'Clawz' Stadium Truck Wheels & Truck Tires mrbrnz Australia For Sale/Trade 0 10-30-2007 02:25 AM
1/10 monster truck/stadium truck alexisonfire Australia Wanted to Buy 3 07-24-2007 08:44 PM
monster truck v. stadium truck for bashing swannco Monster Trucks 6 04-12-2007 08:47 AM
which buggy, stadium truck or monster truck to buy rc_newbie_21 Rookie Zone 11 02-27-2006 07:48 PM
convert stadium truck to street truck salazar44 Electric On-Road 2 06-26-2004 08:26 PM
