Old 08-24-2001, 11:02 AM   #61
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Tim, what do you mean by sp2?
I think it does come with the outdrive savers, cause they are different than trinity's standard outdrive savers. The standard ones have slots in them, those only have a hole drilled.
Speedo is offline   Reply With Quote
Old 08-24-2001, 11:06 AM   #62
Taz_S's Avatar
you should know what SP 4, 3, 2, 1, 0, -1, 2 is what being the post with the most.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 08-24-2001, 12:01 PM   #63
JasonLaDow's Avatar
Send a message via AIM to JasonLaDow
The rear end does not come with the savers. The hole in the ones pictured are for a setscrew that Chad put into his so they would not come off.
JasonLaDow is offline   Reply With Quote
Old 08-24-2001, 12:06 PM   #64
Taz_S's Avatar
Originally posted by Speedo
Trinity's new "CR" conversion...The only thing there I don't have are the hubs!
Ok and i like hot the hub dose have a set for the hing pin too.
Old 08-24-2001, 12:20 PM   #65
I wonder how that NEW rear end would work on a XX4? I would think it would work, being the XXX uses the same arms, etc. As far as a XXX4 is concerned, it is only a matter of time before they update the XX4. I don't think it will be right away but I would say that it will probably be within a year and a half. Even though the XX4 is dominating right now, it is still a good idea to improve so that you can keep yourself that much further ahead of the competition! Would be nice to see the single belt layout make it to the XXX4, would also be neat if it still had the motor up front layout just to keep the margin of difference between cars! The easy access diffs would definately be a godsend!
WailinOnYa is offline   Reply With Quote
Old 08-24-2001, 12:33 PM   #66
Taz_S's Avatar
The easy access diffs would definately be a godsend.
You very right there.
Old 08-24-2001, 03:42 PM   #67
ovalnator's Avatar
Trader Rating: 43 (100%+)
Send a message via AIM to ovalnator
when are the worlds??
ovalnator is offline   Reply With Quote
Old 08-24-2001, 04:46 PM   #68
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
The rear end should not really be called a 'CR' rear end.
The 'CR' upgrade to the Double X cars was to move the rear toe to the pivot blocks, and not on the rear hubs.
The Triple X was designed this way. Trinity has just given the car more rear traction.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 08-24-2001, 04:48 PM   #69
The worlds are in Pretoria S. Africa.
www.rcworlds2001.com
Tim Davis
Old 08-24-2001, 06:59 PM   #70
Moderator
Speedo's Avatar
What? Man, you're really hard to understand!
Old 08-26-2001, 03:38 PM   #71
Taz_S's Avatar
your posting need to be the postman.
Old 08-26-2001, 03:40 PM   #72
Moderator
Speedo's Avatar
I can't understand you!
Old 08-26-2001, 03:46 PM   #73
Taz_S's Avatar
forget it.
Old 08-26-2001, 04:09 PM   #74
Moderator
Speedo's Avatar
NP
I looked, and you have more ppd than me
Old 08-26-2001, 04:13 PM   #75
Taz_S's Avatar
what?
NIP Losi Off-road Tires CraigX R/C Items: For Sale/Trade 3 02-19-2007 07:25 PM
Losi On-road & Off-road inman59 R/C Items: For Sale/Trade 16 07-29-2006 05:36 PM
My last Losi on-road car! inman59 R/C Items: For Sale/Trade 12 07-25-2006 12:33 AM
Losi Nitro On-road Fatboy Joe Nitro On-Road 74 01-26-2004 02:47 PM
Losi off-road for Losi on-road trade coastaltony R/C Items: For Sale/Trade 0 09-29-2001 03:01 AM
