Old 09-18-2002, 05:43 PM   #316
SkipGear's Avatar
Send a message via AIM to SkipGear
FireBlade - You are mistaken. The transmission in both the XXX and XXX-T are exactly the same. There is no difference in the two units. The only changes that are made is the use of a larger spur on the the truck to achieve the lower final drive needed for the larger tires.
The XXX-NT and NTsport parts are interchangable but the NTSport gear is made of a slightly different plastic. Most guys are putting the stock NT gear back in if they have problems with the Sport gear. Also, the nitro and electric cars use different diff's and diff gears.
https://www.facebook.com/skipgear
SkipGear is offline   Reply With Quote
Old 09-18-2002, 07:08 PM   #317
fireblade's Avatar
Send a message via AIM to fireblade
I thought the top shaft gear was 1 or 2 teeth more than the xxx-t?
Hrm, my bad, i must learn to count
fireblade is offline   Reply With Quote
Old 09-18-2002, 09:30 PM   #318
SkipGear's Avatar
The XX and XX-T used to be that way, but the XXX series uses the same drive ratio for both.
The XX used to be 2.19:1 and the XX-T was 2.61:1, they both used the same diff gear but had different top shaft and idler gears.
Old 09-18-2002, 09:41 PM   #319
fireblade's Avatar
ahh ok ic
Old 10-13-2002, 08:58 PM   #320
Send a message via ICQ to RonEB Send a message via AIM to RonEB Send a message via Yahoo to RonEB
O.S. ENGINE IN FLORIDA ON XXX-NT GRAPHITE EDITION
I RECENTLY BOUGHT A .15 CVR SLIDE CARB NON-PULLSTART OS ENGINE FOR MY TRIPLE-XNT GRAPHITE EDITION IN FLORIDA...I WAS WONDERING IF ANYBODY KNEW ANYTHING ON A ROUND-ABOUT SETTING FOR THE NEEDLE VALVE ....LOW END IDLE SCREW AND TEMP ADJUSTMENT...ANY INFO OR TIPS WOULD BE TOOK IN CONSIDERATION....THANX!?!?!
RonEB is offline   Reply With Quote
Old 10-13-2002, 09:33 PM   #321
RonEB,
first of all STOP YELLING! (caps are considered yelling).
OS is a good engine, follow the instructions for set up and break in, the instructions give the start up settings. Other than that you need to adjust for your conditions. The Late Great Ron Paris method for setting low end is to run the engine until it is good and warmed up and then pull it to a stop and listen for the idle speed to drop. if it does you are too rich. Take this with a grain of salt though as Ron was a competition tuner. I would go there and then richen up an hour or two.
The other method is to pinch the fuel line and listen for the engine to rev from fuel starvation. If it does immediately, then you are about done. If it doesn't at all you are either on the edege or too lean. If it takes a second or two you are to rich.
The main adjustment should be done so that you can get a healthy amount of smoke out of the pipe. Otherwise keep an eye on the temp and richen if too hot.
none of these suggestions are good for break in however. Do this carefully with a rich engine that doesn't 4-stroke. the magazines have articles on this at least every three months, see if you can find some.
good luck
Racin Rev is offline   Reply With Quote
Old 10-19-2002, 08:39 PM   #322
All of you Losi fans, check out this site:
Losi World
Action-RC.com is offline   Reply With Quote
Old 11-11-2003, 12:33 PM   #323
SpeedChair's Avatar
Trader Rating: 15 (100%+)
Default XXX-4 Diff/Slipper Setup Question
Hi Everyone,
I just got a XXX-4, and had a question on how to adjust the diffs and slipper on it.
The instruction doesn't say too much about how to adjust it so hoping someone can provide some extra details on how hard I need to tighten the diffs.
The instruction states that I must hold the two left tires and throttle the controller 1/4 of the way. I assume if the right tires aren't spinning, the diff is too loose. However, could my slipper be too loose too?
Any help would be appreciated. Hope this car is as fun as my Kyosho 7.5. I know it will be cleaner. LOL.
SpeedChair is offline   Reply With Quote
Old 11-11-2003, 05:51 PM   #324
LosiFromHell986's Avatar
Send a message via AIM to LosiFromHell986
Hey Guys, I was just wondering if any of youguys have Losi LXT's? I have one and it's like my favorite... anyways, do any of you have a tranny for one? Kinda wierd question but it's cuz I stripped the center Diff gear, and it's irreplaceable! LMK, PM me or something...
LosiFromHell986 is offline   Reply With Quote
Old 11-11-2003, 06:51 PM   #325
rushdude's Avatar
Send a message via AIM to rushdude
I have the xxx-nt with a fantom .12 in it. I am very happy with the truck its durable and great for racing. After buying this I will never buy another stadium truck.
rushdude is offline   Reply With Quote
Old 11-11-2003, 09:35 PM   #326
Default Re: XXX-4 Diff/Slipper Setup Question
Originally posted by SpeedChair
Hi Everyone,
i check my diff by holding the spur and left tire and try to rotate the right tyre..if it rotates easily its loose if not its ok...usually i run my front diff a little tighter than the back for wide or open tracks...vice versa on tight or just replace the front with one way or spool....as for the slipper...i just set the buggy on the track and press it down to hold all four tyres and pull the trigger like revving a nitro car...if it slips from the beggining of the throttle then its too lose if it slips like after the half of the throttle then its ok....and it depends on the track condition too...
thats just how i set mine...there's a lot of ways you could use out there
Los1Fan is offline   Reply With Quote
Old 11-12-2003, 11:15 AM   #327
SpeedChair's Avatar
Thanks for the input LOS1FAN....I'll try that and go from there.
NIP Losi Off-road Tires CraigX R/C Items: For Sale/Trade 3 02-19-2007 07:25 PM
Losi On-road & Off-road inman59 R/C Items: For Sale/Trade 16 07-29-2006 05:36 PM
My last Losi on-road car! inman59 R/C Items: For Sale/Trade 12 07-25-2006 12:33 AM
Losi Nitro On-road Fatboy Joe Nitro On-Road 74 01-26-2004 02:47 PM
Losi off-road for Losi on-road trade coastaltony R/C Items: For Sale/Trade 0 09-29-2001 03:01 AM
