Old 06-18-2002, 01:48 PM   #301
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Yes, I am talking about the rear hubs. Do the trinity rear hubs move the ballstud out, or just allow to to adjust the height?
Thanks,
Josh
Speedo is offline   Reply With Quote
Old 06-18-2002, 02:12 PM   #302
SkipGear's Avatar
Send a message via AIM to SkipGear
Default Trinity Hubs
The original trinity hubs only allow you to raise and lower the ball stud. They use the same spacing as the stock hubs and with 2 #4 washers under the ball stud, the ball is supposed to be in the same position as the stock hub. They are off by a small amount but not enough for most to notice.
The CRE kit still keeps the ball studs in the same relative postion as the original hubs but change the pivot point of the dogbone (CVD in their case). This shortens the dogbone and creates more dogbone scrub. This makes the car generate more roll stiffness under power and load. It will help the car square up on extremely slick tracks. There is a trade off though, the car will not handle the rough stuff as well with the added dogbone scrub.
https://www.facebook.com/skipgear
SkipGear is offline   Reply With Quote
Old 06-18-2002, 10:03 PM   #303
Send a message via AIM to XXX-NT RACER
Default xxx-nt bench built
i should be getting my xxx-nt bench built tomorrow it comes with the picco .12 i cant wait does anyone know top speed on this truck and best setup?
XXX-NT RACER is offline   Reply With Quote
Old 06-22-2002, 12:14 AM   #304
shrekair's Avatar
Trader Rating: 9 (91%+)
losi website generally has some good setups
shrekair is offline   Reply With Quote
Old 07-18-2002, 11:59 AM   #305
Send a message via AIM to FastFreddy
I just tried to adjust my xxx-nt diff and the wheel just spins, does not tighten??? Now I have NO diff action whereas before it was pretty good. What might have happened? This is my first adjustable diff. Thanks, Tim
FastFreddy is offline   Reply With Quote
Old 07-18-2002, 12:18 PM   #306
Forget it...I found it. The locking nut in the left side outdrive is stripped out I don't know why that has happened but I'm on the phone with my LHS now!
Old 07-18-2002, 10:06 PM   #307
i had the exact same problem but i gotta question for everyone too, does the nt sport diff use that same part as the normal nt?
Old 07-19-2002, 08:55 AM   #308
SkipGear's Avatar
The only difference in the Sport is that is uses a single sping in the diff instead of the 8-12 bellville washers. Other diff parts are the same.
Old 08-10-2002, 05:23 PM   #309
Evil_S10's Avatar
Send a message via AIM to Evil_S10
Losi part #a-5062. If anyone needs a set of 1.2" Titanium Nitrided shock shafts, I have four of them NIP. I will sell them for $15 shipped. E-mail me at [email protected] for more info.
Evil_S10 is offline   Reply With Quote
Old 08-23-2002, 11:20 PM   #310
does anyone know what is needed to convert an xxx too xxxt??it seems that i only need to change only front rear shock towers...will the front xxx upright fit the wider rims of xxxt without any change??
fReShJiVe is offline   Reply With Quote
Old 08-23-2002, 11:23 PM   #311
kino2's Avatar
I think u need a longer chassis also.
kino2 is offline   Reply With Quote
Old 08-23-2002, 11:23 PM   #312
kino2's Avatar
and sus arms.
Old 08-24-2002, 08:54 AM   #313
Send a message via AIM to Ben Ellis
See my post in XXX-T thread.
Ben Ellis is offline   Reply With Quote
Old 09-18-2002, 05:18 PM   #314
fireblade's Avatar
Send a message via AIM to fireblade
Yea there the same, in a XXX-T a XXX Diff gear is used.
fireblade is offline   Reply With Quote
Old 09-18-2002, 05:21 PM   #315
fireblade's Avatar
The Truck looks like a converted buggy. But it has differences.
Yes, A-Arms,Shocktowers etc. Chassis too. Your better off buyin a MFE xxx-t. Plus, The gear ratios are almost the same but the buggy is a tad lighter than the xxx-t so they changes the ratios on it. But the same diff gear is used.
NIP Losi Off-road Tires CraigX R/C Items: For Sale/Trade 3 02-19-2007 07:25 PM
Losi On-road & Off-road inman59 R/C Items: For Sale/Trade 16 07-29-2006 05:36 PM
My last Losi on-road car! inman59 R/C Items: For Sale/Trade 12 07-25-2006 12:33 AM
Losi Nitro On-road Fatboy Joe Nitro On-Road 74 01-26-2004 02:47 PM
Losi off-road for Losi on-road trade coastaltony R/C Items: For Sale/Trade 0 09-29-2001 03:01 AM
