Old 10-03-2001, 07:13 AM   #136
JasonLaDow's Avatar
Send a message via AIM to JasonLaDow
The easiest thing to do if you are happy with the way the car handles otherwise is to adjust how you approach the jumps. Just as the front wheels hit the base of the jump, let off the throttle. Right after that give full throttle and this will take weight off the front of the car causing that end to lift. The first thing I usually do though in cases where even changing the approach doesn't help is to increase the rear ride height slightly. This keeps the rear of the chassis from bottoming out when you hit the face of the jump.
Jamracing- XXXNT setups don't transfer well to the electric truck. Francis' current XXXT setup (which I think is his Nat's setup) should work well for you. You can find it on the Losi site, or I could give you what I've been running lately on my truck.
JasonLaDow is offline   Reply With Quote
Old 10-03-2001, 07:37 AM   #137
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
guys on the nitro clutch bearings...i put bocas ceramic bearings in my nitro truck....now two years later, they are still in great shape....well worth the 35 bucks....
Matt M. is offline   Reply With Quote
Old 10-03-2001, 08:10 AM   #138
SkipGear's Avatar
Send a message via AIM to SkipGear
Mr. Losi - The only problem with the ceramic bearings is that I believe that they are illegal at ROAR and IFMAR events. Although I doubt anybody will know to tech them.
TC3 - As far as setup goes for the XX4, try the most recent Todd Hodge setup. That is very close to what I have been running for over a year and works quite well. You might also try the setup Francis ran at the nats. I haven't tried that one but am told it works very well. On the Hodge setup, you might try changing the rear dampening from the 54 - 40 to 56 - 25 or 27.5. I have never liked the 54 - 40 rear's. It makes the back of the car to sluggish, kind of the wet rag syndrome.
SkipGear is offline   Reply With Quote
Old 10-09-2001, 09:31 PM   #139
007yoshi's Avatar
Well I'm selling my xx4 to someone who wants it. Everything was fine till all the sudden a bunch of problems came up. Its too much money now... who all has had really bad belt problems even with the new green ones? They were skipping like mad. Oh and it was a used xx4 I bought so that might explain the problems I had.
007yoshi is offline   Reply With Quote
Old 10-09-2001, 09:56 PM   #140
emer's Avatar
Trader Rating: 32 (97%+)
Send a message via ICQ to emer Send a message via Yahoo to emer
Default belt problems
007yoshi,
I experiance the same problem too. When I got my xx-4 and used it for 2 years, one after another the belt broke. after I replace them they are working fine, belt slipping does not happen to me.
I replace front and side blue and rear red.
however in my rally weapon, just for 2 months on weekly used, my side belt green snap too, but now ok. I don't really know which is durable the blue or the green, I think belts for the xx-4 and rally weapon has to be repalce every year or every other year.
The only active off-road club in the Philippines, a non-profit organization called QCRCCC (Quezon City Radio Control Car Club).
Now 19TH Years in Service! "The Fun Never Ends"
emer is offline   Reply With Quote
Old 10-09-2001, 10:58 PM   #141
The green belts are the most durable ones and are meant to be used in the XX4!
007yoshi: The slipping is most likely being caused by worn pulleys, if you have already replaced the belts with new ones!
When the teeth on the pulleys get worn down and smoothed over they will slip easily!
WailinOnYa is offline   Reply With Quote
Old 10-10-2001, 02:33 PM   #142
Administrator
Matt M.'s Avatar
skip....i did not know that.....thanks...do you have any distibuters for you losi rear end mod????
Old 10-12-2001, 12:40 AM   #143
SkipGear's Avatar
Yoshi and others - It is important with the XX4 that anytime you break a belt, replace all the pulleys that the belt ran on. If the belt skips enough that it breaks, the pulleys are toast also. It may seem expensive but it will make everything last longer overall. If you are repeatedly breaking front belts, check to make sure the chassis has not cracked where the front threaded inserts go thru. This allows the front suspension assembly to twist and stretch the front belt to the point of breaking.
Mr. Losi - right now I am the sole distributor. I have had offers from Schumacher and a few other places to distribute but I am just doing this myself and have a hard time keeping up with the work as it is.
https://www.facebook.com/skipgear
Old 10-16-2001, 09:48 PM   #144
Administrator
Matt M.'s Avatar
skip..ok, i will be in touch....
Old 10-17-2001, 01:34 AM   #145
Usagi's Avatar
Any comments on the XXXT MF? I really want one, but I thinking if its worth it
Thank you
Usagi is offline   Reply With Quote
Old 10-17-2001, 10:27 AM   #146
Taz_S's Avatar
Usagi: yes it worth it.
Just for all the Hop Ups and only $50 more that not bad.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 10-18-2001, 07:42 AM   #147
Usagi's Avatar
Hey thabk you where is the cheapest place I can get one?! Thank you again
Old 10-18-2001, 09:42 AM   #148
Taz_S's Avatar
at our LHS it going for $219.00
Old 10-18-2001, 11:25 AM   #149
Usagi's Avatar
Thats is a nice price.
Old 10-18-2001, 11:55 AM   #150
Taz_S's Avatar
yea but to bad the xxx-s stock cost 199.99 with no hop ups.
NIP Losi Off-road Tires CraigX R/C Items: For Sale/Trade 3 02-19-2007 07:25 PM
Losi On-road & Off-road inman59 R/C Items: For Sale/Trade 16 07-29-2006 05:36 PM
My last Losi on-road car! inman59 R/C Items: For Sale/Trade 12 07-25-2006 12:33 AM
Losi Nitro On-road Fatboy Joe Nitro On-Road 74 01-26-2004 02:47 PM
Losi off-road for Losi on-road trade coastaltony R/C Items: For Sale/Trade 0 09-29-2001 03:01 AM
