Old 12-02-2006, 09:47 AM   #1
Default Direct Solder or Deans
I am curious to know how the racers our there are connecting their batteries to the ESC? I assume there are some with Deans and some directly soldering. What is the advantage/dis to both. Thanks for the help.
andy
aduncan is offline   Reply With Quote
Old 12-02-2006, 10:14 AM   #2
R40Victim's Avatar
Deans are practically ZERO resistance, so direct solder is really just a "hard headed about racing" technique... Unless you're competing with Atsushi Hara...save yourself the headache of keeping an iron hot and ready every time you wanna switch batteries.
R40Victim is online now   Reply With Quote
Old 12-02-2006, 10:25 AM   #3
RAZ49's Avatar
Stay with the Deans connectors. I doubt you would even see any difference between the 2 as far as performance goes but you would sure see the hassle of soldering all the time.
RAZ49 is offline   Reply With Quote
Old 12-02-2006, 10:26 AM   #4
Trader Rating: 28 (100%+)
I run deans in my offroad cars b/c there is generally no power in the pits. Beats the heck out of buying and running a generator. Plus it's just easier. Indoor carpet racing I solder since there is power at each pit, and it's difficult to shove a bunch of wires under a 1/12 scale body.
Plus with plugs, if you get em soldered right the first time you'll never toast a speedo due to backwards connections. But if you direct solder and make it so the wires will only reach the place they're supposed to you really can't mess that up either. But for some reason I see guys smoke speedos at least a couple times a year direct soldering.
jbrow1 is offline   Reply With Quote
Old 12-02-2006, 10:37 AM   #5
D Hunt 3's Avatar
Send a message via MSN to D Hunt 3
I direct solder because I don't like to solder deans. I don't have to worry about putting positive wire on negative/ negative wire on positive because with my car there's only one way for the wires to reach. I also think it looks cooler with direct solder.
D Hunt 3 is offline   Reply With Quote
Old 12-02-2006, 11:34 AM   #6
If you don't need the convenience of connectors then direct soldering saves you some cash otherwise spent on connectors.
There is virtually no difference in resistance between Deans and Soldering.
AreCee is offline   Reply With Quote
Old 12-02-2006, 12:46 PM   #7
PIITB's Avatar
deans look ugly. too much wiring. gets expensive in the long run.
and after a few months they plugs get dirty and resistance does increase dramatically.
i use the euro plugs.
PIITB is offline   Reply With Quote
Old 12-02-2006, 01:32 PM   #8
I agree!
Old 12-02-2006, 08:28 PM   #9
Both ways work good..
Dave.H is offline   Reply With Quote
Old 12-02-2006, 08:36 PM   #10
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Corally plugs are the way to go.... As neat as direct soldering without the need for a soldering iron always handy... Work great if you need to disconnect the battery quick but like soldering you could easily reverse the polarity.
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 12-02-2006, 08:47 PM   #11
Eggyolkeo's Avatar
Can't beat Corally. No significant difference between this and direct solder in terms of resistance.
Benefit is that you're not exposing the first and sixth cell to soldering iron heat every time you use a pack. It's faster. Looks just as trick. Deans are ok but require more wiring which equals more resistance. They can be fiddly when tight too.
Eggyolkeo is offline   Reply With Quote
Old 12-03-2006, 11:12 PM   #12
Thanks for the posts. I appreciate the input. I am not sure I want to spend my time soldering at home or at the track. If I do it at the track I will save lots of money (no plugs/wires), but I have the hassle of soldering at the track.
Andy
Old 12-04-2006, 03:04 PM   #13
jgroenhof's Avatar
Default I use Deans + tips
I use Deans plugs because I have a little boy in the pits. The downsides are a little extra weight, due to the extra wire. You need some slack to plug/un-plug.
I have had the extra weight from wire shear the wires going into two Novak ESC. I hate resoldering those!
I think I'll move to direct solder when the boy is older.
Applicable soldering tips.
Color code your batteries with a red and green sharpie.
Use a high watt soldring iron. Less time for heat transfer.
Use a clip on heatsink on battery bars, motor tabs, diodes, or anything.
Johnny G
OCRC.
jgroenhof is offline   Reply With Quote
Old 12-04-2006, 10:37 PM   #14
Casper's Avatar
Trader Rating: 34 (100%+)
Deans all the way. You can get the pigtails for batteries. Saves the hassel of having to solder the plugs on wire for batteries. You still need to solder the plugs on your ESC and your charge.
Advantage. I have NEVER had a deans plug fail. I have never had to run back to the pits due to a failed solder joint. The have less resistance then a solder joint that has been redone 50 times! You do not risk heating up your 1 and 6th cell like someone already mentioned. They make life simplier in the long run. I have been running highly competative stock racing for the last 3 years. Deans have not slowed me down one bit!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 12-04-2006, 10:59 PM   #15
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Deans all the way. Never had a problem with them.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Solder / Solder Stand - Available Online? RC12 Electric On-Road 7 05-01-2008 10:20 AM
Solder Help Please tonyking73 Electric Off-Road 11 09-17-2007 03:42 AM
Serpent starter box,Deans discharger,Deans battery jig,Indi battery equalizer SRAD R/C Items: For Sale/Trade 5 03-14-2007 05:32 PM
What solder Mossie Australian Racing 1 12-08-2004 05:03 PM
Solder TC3 Electric On-Road 13 02-08-2003 09:44 PM
