Old 12-01-2006, 09:40 PM   #1
xxx-ntad2 racer's Avatar
Trader Rating: 24 (100%+)
Default xxx front a-arm fit on xxx-bk2???
i was wondering if a plastic xxx buggy front a-arm will fit(work) on a xxx-bk2. i know the bk2 arms have two adjusting holes for the hub carrier and the xxx dosn't. but if they do work will you have to adjust the turnbuckles? lmk. thanks for the help!
Hobby Pro USA
www.Hobbyprousa.com
xxx-ntad2 racer is offline   Reply With Quote
Old 12-02-2006, 05:42 AM   #2
j97
j97's Avatar
it will fit not sure about adjustment but it will fit
j97 is offline   Reply With Quote
Old 12-02-2006, 10:03 AM   #3
Scottmisfits's Avatar
They do work. It just depends on which holes you use whether you need to adjust your turnbuckles. All I use is one of the RPM camber gauges.
Scottmisfits is offline   Reply With Quote
Old 12-02-2006, 04:34 PM   #4
I don't think the XXX arm will work with the VLA front steering caster block. If I remember right the caster block will hit the arm. You will need to use the outside hole of the caster block if it will work. If you use the inside hole you will be too wide. If you have to adjust the camber link by lenghtening it you are too wide. If you change to a xxx caster block with the xxx arm all should work.
plumslow is offline   Reply With Quote
Old 12-02-2006, 08:25 PM   #5
SlobbaTech's Avatar
If you put a XXX front arm on a BK2 front end use the inside hole on the caster block for the hinge pin is the same thing as running the inside hole on the arm/block on BK2 arms.
Hot Bodies, HPI, Novak Electronics, JR Propo, Lunsford, Skipgear.com, Planet R/C, Vinyl Graphics Unlimited, JConcepts, B-Mods Racing, CRCRC, King's R/C Raceway, Avid R/C, GMK Supply, & Pacific Coast Hobbies.
SlobbaTech is offline   Reply With Quote
****Revo****Integy Alloy Front, rear and middle-front skid plate set in silver. jf45 R/C Items: For Sale/Trade 6 05-07-2008 12:04 PM
MBX5 Front Shock Tower or MBX5R Front Shocks skelly1344 R/C Items: Wanted to Buy 2 08-09-2007 06:54 PM
3 sets of Front 4wd custum front tires with pics Tony Rivas R/C Items: For Sale/Trade 5 02-20-2007 12:55 PM
Hyper 7 cnc front knuckles/front upper arms trashedmaxx R/C Items: For Sale/Trade 2 09-17-2005 01:28 PM
Alum Tamiya TA04 Front Steering Block / Front Upright Alvin Singapore R/C Racers 2 02-04-2002 07:50 PM
