Old 11-05-2006, 01:31 PM   #1
Default I need a durable electric rig!
Well I just got the Mamba Max 5700 system for my old XXXT i got a while back. Needless to say this system is nuts, I can't imagine ever wanting or needing the 7700, i am running 3300's and at the stock settings the mamba max is s beast ripping up the track. My rear tires seriously get twice as big in diameter and become spikes. Anyways the system is tearing apart my truck, and I dont want to tune it down or make it slower, but I want my truck to run, and run faast!. I have pretty much givin up with trying to make it reliable, because there is no hope of that anymore. I am looking for a reliable truck/buggy to run my mamba max system in. I really want a 4wd buggy, like the Kyosho Lazer, or similar, something cheap like around 2 or 300 that I can get in a kit and build myself with titanium bulletproof everything, I also love truggy's and stuff. Basically I just want to switch to 4wd for this monster power plant. Any sudgestions of a really reliable, able to take a lot of abuse and a lot of torque and speed. Or do I have to convert an 1/8th scale buggy or something. BTW, how do you think that would work, an 1/8th scale buggy with the mamba max, I think even with the significant weight addition it would still be fast and way durable.
RoostAZ is offline   Reply With Quote
Old 11-05-2006, 02:16 PM   #2
streetracer745's Avatar
Send a message via AIM to streetracer745
get the losi XXX-4 graphite (http://www.teamlosi.com/Products/Def...rodID=LOSA0015 ) i dont own one but someone at my track has one. that thing is a beast. he can run it with most revos. he said its extreemly reliable. oyu could take all your servos off your XXXT and put it on there to, so you wouldnt be paying hundreds for new servos. but i have heard great stuff abnout that buggy. and i drove one at my track and LOVED it. so much fun compared to a 2wd truck.
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 11-05-2006, 04:55 PM   #3
the XXX4 is really nice, but the Kyosho ZX-5 (and about $60 less) with the aluminum shock tower mount is supposed to be more durable. Any 4 mod is going to break, and it is usually the stuff that you think would not break it that cause the breaks.
HTH
Rod
gatermaxx is offline   Reply With Quote
Old 11-05-2006, 05:15 PM   #4
glassdoctor's Avatar
The Kyosho is $279 at my LHS and the XXX4 I think is the most fragile 4wd... at the races there are way more DNFs for the XXX4 than any other car.
Maybe it's the just drivers but I don't think my track is the only one like this.
glassdoctor is offline   Reply With Quote
Old 11-05-2006, 06:52 PM   #5
dallasv8's Avatar
Talking stampede it
chuck it in a traxxas stampede, you will have a lot of fun with it
RC10B4
FT RC10T4
Proline Pro 2 SCT
Piss on holden
dallasv8 is offline   Reply With Quote
Old 11-05-2006, 06:55 PM   #6
their is a xxx4 for sale at my LHS for 200, so i could get one of those easy. but I am not a fan of graphite at all, from having my graphite MF2 XXXt, and I am also not a fan of belt drives. Idk I could build that cheap enough. Would you think a 2wd buggy would be MORE durable than 4wd, because I could also get a n associated 2wd buggy for 160
Old 11-05-2006, 11:12 PM   #7
I have thought about that, I wanted a stampede, but I want it to be in a race truck not just basher. Do you think an emaxx would be cool with one, an electric race emaxx. That actually might be a good idea...
Old 11-06-2006, 12:02 AM   #8
builthatch's Avatar
Send a message via AIM to builthatch
i am curious, what are you breaking? i am running 6X4200 and the 7700 in an mf2.
5'16", 154.2 kg
builthatch is offline   Reply With Quote
Old 11-06-2006, 07:30 AM   #9
I turned my tires inside out and put packing tape on the inside of my tires. Flip them back right side out and inserted foam and tape. The tires don't ballon nearly as much now. I run the 5700.
Spoook is offline   Reply With Quote
Old 11-06-2006, 12:19 PM   #10
I agree I own a losi XXX4G+ and its not been a very good buggy.The XXX4 is certainly the most fragile RC vechicle I've ever owned.
slink is offline   Reply With Quote
Old 11-06-2006, 12:39 PM   #11
sport10's Avatar
In stock form the XXX-4G+ has a few weak points but once upgraded the car becomes durable. Mainly upgrading the front and rear pivots to aluminum and doing the kingpin mod available at 4wdrc.com makes this a pretty tough car. There is nothing wrong with the XXX-4 belt drive it can take quite a bit of abuse and is low maintainence. I do wonder what you found you do not like about Losi's graphite used on the MF2. Mine has been exceptionally durable and IMO the best graphite available.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 11-08-2006, 12:14 PM   #12
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Probably the most durable 4wd buggy you will find is the MRC / Academy SB Series of vehicles. I beat the crap out of both of them, and hit pretty much everything you could when I ran at Wolcott hobbies with the V1 and it was a tank. The V2 also proved as durable when I ran it and the parts were also were more refined than the V1. the V1s parts (namely the arms) have slightly more flex to them but are extremely beefy.
If you are just looking for a beater vehicle, the SB Pro V1 can be had now onsale at MRC's site I think for 180? with a center oneway, get the 74 tooth spur gear, you should be all set.
The V2 can be had at ultimate hobbies for $208 I believe and if not there Stormer has them for $230ish . Only thing I would get right away for the vehicle would be the alloy shocks from Academy and run a o-ring on each side of the rear axles to push the dogbones in slightly to prevent bone fallout.
V2 out of the box with those changes performed as well as my fully setup SB Pro V1 ever did.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 11-08-2006, 12:23 PM   #13
I have hit stuff with my XXX4 that would have broke my stock truck, or a revo, and had nothing break, and then I have clipped a pipe at low speeds and broke an arm. With the correct aluminum mounts, and the correct length screws in the front diff, this thing is durable. other than maybe the arms, but with lap times that can be equivalent to an 1/8th nitro buggy, and skinny arse plastic arms, what do you expect?
Rod
Old 11-09-2006, 12:35 AM   #14
XXX4 has a reputation as a fragile car... when compared to other 4wds (apples to apples) it's just a fact. No offense to xxx4 owners...
Old 11-09-2006, 06:45 AM   #15
I have to admit ive broke alot of stuff on my XXX4, but since upgrading to the all alum pivot blocks, getting the carbon fiber chassis brace, and LEARNING TO DRIVE IT, ive stopped breaking alot of stuff... the usual pipe clip and snap goes an arm or spindle, but that happens to everyone.
The car is an absolute rocket with my 12x1 orion, a 5700 would be insane! The car does handle awesome,but ive only ran on indoor clay blue groove, what type of track to do run usually.
Crcrc Track Director
TL Mf2
Duratrax Raze
FowLer is offline   Reply With Quote
What is the most durable 1/10 TC party_wagon Nitro On-Road 15 12-02-2007 06:13 PM
MOST DURABLE CAR UNDER 250? SMOOOZZZ Electric Off-Road 22 09-23-2007 03:17 PM
Durable T/C Car palisocm001 Electric On-Road 9 05-20-2007 01:00 AM
Which is the Most Durable/Reliable Electric vehicle. SMOOOZZZ Electric Off-Road 15 03-28-2007 05:04 PM
The most durable electric touring car sim600 Malaysian R/C Racers 51 01-05-2004 02:18 AM
