Old 11-04-2006, 06:38 PM   #1
builthatch's Avatar
Send a message via AIM to builthatch
Default good bashing tires for stadium truck on asphalt?
i currently have PROLINE speedhawgs on my mamba 7700 powered mf2 and they give me very little traction on asphalt. they look cool, but they are pretty much useless. yes, i know i have waaay too much power for a 2wd truck, but still...they are horrendous.
I didn't band tape them inside, so they balloon INCREDIBLY any chance they have, especially at full speed, but...regardless, the give me zero traction, both front and rear.
is there a nice sticky tarmac/concrete bashing tire out there? I'd like something like the speedhawgs but maybe 100% more soft/sticky, and with an insert that is 100% more hard than the one they provide.
years ago i used to run BoLink foams on my ol' XX, atleast on the rear, but i was running some sort of 27T at the time.
5'16", 154.2 kg
builthatch is offline   Reply With Quote
Old 11-04-2006, 11:50 PM   #2
builthatch's Avatar
maybe something like this? http://www.teamtrinity.com/shop/tires/truckfoam.html
if i was to run these, i always thought chunking was an issue with foams on asphalt....what would i run that would give me the best compromise between traction and durability?
5'16", 154.2 kg
Old 11-05-2006, 12:55 AM   #3
SpeedBump57's Avatar
Take a look at these....
http://www2.towerhobbies.com/cgi-bin...p?&I=LXDT97&P=
http://www2.towerhobbies.com/cgi-bin...p?&I=LXLN12&P=
Either of those two will work well.
SpeedBump57 is offline   Reply With Quote
Old 11-05-2006, 08:39 AM   #4
builthatch's Avatar
Originally Posted by SpeedBump57
so those would be better than the speed hawgs i run? are the speed hawgs known to be bad? they are just so slick; they don't grab at all.
do you definately suggest taping inside with these tires?
5'16", 154.2 kg
Old 11-05-2006, 11:02 PM   #5
builthatch's Avatar
up for more suggestions regarding ^ ^ ^
5'16", 154.2 kg
Old 11-06-2006, 04:42 AM   #6
fathead's Avatar
I have raced with Road Hawgs and they work pretty good.
I have a set of Striker II's that I am going to use this weekend, but they seem harder than the Road Hawgs just feeling them.
Slavich Design
fathead is offline   Reply With Quote
Old 11-06-2006, 05:39 AM   #7
ta_man's Avatar
Trader Rating: 151 (100%+)
Default Street bashing tires
My experience with the Striker II tires is that they are very soft rubber. I think you will enjoy the traction the provide but your wallet will not enjoy the rate at which they wear. I have used them indoors on carpet and they are so soft they actually wear on carpet. I tried a set on the street once and they were about halfway worn out in just a few battery packs.
I have uses the Road Rage on the street too and found them to be somewhat better than the Speed Hawgs. What I do is use different tires front and rear to balance traction. One of my street trucks right now has the Speed Hawgs on the front and useses Road Hawgs (similar to the Road Rage) in the rear.
If there is an RC dirt track near you, maybe your best option is to find someone selling used (worn out) dirt tires. I use my old dirt tires on the street and have also been able to get used (too worn for dirt but great for asphalt) tires really cheap. Run them as slicks until the rubber gets too hard from age to have any grip.
ta_man is offline   Reply With Quote
What is a good monster truck for bashing? T4 Razer Monster Trucks 25 09-23-2008 11:37 PM
What is a good monster truck for bashing? T4 Razer Nitro Off-Road 31 08-24-2008 10:55 PM
street traction tires for bashing race truck beez Electric Off-Road 10 05-25-2008 10:23 PM
monster truck v. stadium truck for bashing swannco Monster Trucks 6 04-12-2007 08:47 AM
suggestions wanted for tuning stadium truck (mf2) for asphalt builthatch Electric Off-Road 1 11-29-2006 04:43 PM
