Old 11-03-2006, 04:11 PM   #1
Default Reedy Neo Question
has anyone hear had any issue with the neo motor breaking or hav'n the windings come apart?
Dick Trickle is offline   Reply With Quote
Old 11-04-2006, 10:14 AM   #2
knowbodys had problems?
Old 11-04-2006, 10:33 AM   #3
Tech Legend
Wild Cherry's Avatar
Not me .....
Love the Neo , best motor I`v ever run....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 11-04-2006, 10:43 AM   #4
Mine works great. Haven't had any problems.
kzacher is offline   Reply With Quote
Old 11-05-2006, 02:08 PM   #5
streetracer745's Avatar
Send a message via AIM to streetracer745
i love my 4star. but its onroad. the offroad ones are built the exact same way though. only less turns. and i love it. im considering getting one for my race truck. incredibly tunable and easy to work with. never had a problem
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 11-05-2006, 03:42 PM   #6
Davidka's Avatar
Trader Rating: 77 (100%+)
I think I read somewhere that the Neo's have adjustable timing. If that's true have any of you tried changing the timing? I wonder what the effect would be like compared to a brushed motor.
Old 11-05-2006, 03:49 PM   #7
Tech Legend
Maybe I`m wrong , but I don`t believe you can adjust the timing on the Neo even though there are timing marks on the can .
George W. Cherry
Old 11-05-2006, 07:52 PM   #8
it can change the timing. but all it does is change the rpm difference. leave the motor were it is set on timing and change the gear ratio. it doesnt mess up the motor as bad. if you gear it right, then the motor should be great in all conditions on the stock timing. dont change the timing, it doesnt do much and screws the motor.
Old 11-05-2006, 11:06 PM   #9
Tech Legend
street racer , I`v tried, you can`t adjust the endbell on a Neo like a brush motor .
Maybe you know how and I don`t ?
Let me know...
George W. Cherry
Old 11-06-2006, 01:51 PM   #10
lossen the 3 screws on the endbell about half way. then look at the black ring that is touching the can. not the plate on the far back or the plate that connects the wires, but the ring in between the wire plate and the can. take a small flathead screwdriver and put it into one of the small notches and push it towards the number you want the notch to line up with. thats the new timing. im pretty sure that the lower the number, the more bottom end rpm power it has and the higher the number the less low rpm power, but im not sure.
Old 11-08-2006, 08:29 PM   #11
Tech Legend
Street,
understand how to adjust, thanks to you.
George W. Cherry
Old 11-08-2006, 08:38 PM   #12
make sure you change your gearing when you change the timing though. otherwise you will fry your motor. im pretty sure that the higher you set the timing the higher you need your gear ratio to be. im nto sure what the actual settings are though. the stock setting of 2 on timing with about a 9.5 final drive ratio should be great for all conditions. i can drift and race on my settings. so be careful changing timing, im nto sure if warranty covers it.
Old 11-08-2006, 08:49 PM   #13
i take back the 9.5 final drive. that is in my 4* yall are probly running a 1 or 2 star. im not sure what yalls would be
Old 11-09-2006, 11:50 AM   #14
MustGoFaster's Avatar
I have a Neo 3 Star installed in my BJ4-WE and using the Sphere Comp ESC (w/supplied capacitor).
I was very happy with the performance but after only 2 weeks the rotor failed. The cylindrical magnet which is supposed to be permanently fixed on the shaft actually moved. Keep in mind that I take very good care of my equipment:
- Not running it for more than 5 minutes without a break
- Checking motor, esc and battery temperatures often
- Making sure the buggy rolls freely without any drag on the driveline
The good news is that within 7-10 days of returning the motor to Associated they shipped me a brand new replacement unit.
The explanation was that there was a small batch of rotors produced that had a manufacturers defect.
Associated handled this issue well and I would not hesitate to recommend or buy another one.
I have not a problem with the replacement motor.
P.S. The nice thing about the Sphere comp ESC is that I was able to install a brushed motor while I was waiting for the Neo to return.
MustGoFaster is offline   Reply With Quote
Old 11-09-2006, 01:59 PM   #15
3 star in a buggy? must have been a strange gear ratio for the buggy or else you had a very smooth surface. i didnt think the 3 star was built for offroad racing though?
Reedy Quasar Pro Question hitman Radio and Electronics 0 05-29-2008 06:32 PM
The Real Reedy Race Question is....? myvantage Electric On-Road 31 05-03-2007 07:16 AM
Reedy 19t enbell question... WheelNut Electric On-Road 2 10-10-2005 07:25 PM
Reedy Brushless Question. hollisst Electric Off-Road 3 05-23-2005 06:00 PM
reedy quasar question??? church Electric On-Road 1 01-27-2004 11:00 AM
