Old 10-24-2006, 10:18 PM   #1
Dougg's Avatar
Default One way diff?
I'm buying a xxx4 this week. I'm racing 2wd buggy at the moment. What is the bennifit of a one way diff on a 4wd buggy? The track that I race on is a blue grove track. Please tell me the pros and cons on this.
Doug
Dougg is offline   Reply With Quote
Old 10-25-2006, 10:43 AM   #2
sport10's Avatar
The oneway will make the 4wd behave more like your 2wd buggy when turning into a corner because it allows the front wheels to disengage under braking and coasting but when you get on the power the front wheels lock together giving more traction and stability out of the corner. The best oneways to get for the XXX-4 are the english made ones. They are more heavy duty and last much longer than the one made by Losi. The Losi unit was made for onroad and doesn't holdup very well offroad. The English oneway can be had at www.4wdrc.com
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 10-25-2006, 02:31 PM   #3
Dougg's Avatar
Thanks! I'll be aware of getting the one way. I will try the stock front diff first, so I know what that feels like. As I've read, I'm sure I will go to it. Thanks for the suggestion about the english one way. I'd rather spend the money once.
Doug
Old 10-25-2006, 04:11 PM   #4
Donnie's Avatar
Being sort of new at this I can only say that the one way on my xxx4 made a world of difference!!!. Just like turning your truck on a dime!..Then squeeze the trigger and the 4wd kicks in and the thing disappears. I picked up the Losi unit and have not had any bad luck yet, that being said I am sure the English unit is superior
Donnie is offline   Reply With Quote
Old 10-25-2006, 05:36 PM   #5
I have both types of one-way and much prefered the losi unit.
The english / apex / dc racing unit is substantially heavier than the losi from memory something like 5 times heavier. This extra weight affects how the car handles jumps and also how the car accelerates.
chuckyegg is offline   Reply With Quote
Old 10-25-2006, 05:47 PM   #6
Donnie's Avatar
interesting....not to mention the 80 bucks..
Old 10-25-2006, 05:55 PM   #7
sport10's Avatar
The losi unit blows out oneway bearings too easy. This was even acknowledged by team losi. Scoreing certain parts of the losi unit helps make it live longer. The extra weight up front might help give the xxx-4 better steering too. If you ever get a chance to run an XX-4 you will notice you get better steering and bump handling from its more forward weight distribution. Converting to an X-5 will give you handling similar to the XX-4 but with the added benefit of a one belt drivetrain like the XXX-4.
Associated B44
Associated B6
Associated TC7.1
Old 10-26-2006, 03:19 PM   #8
Dougg's Avatar
I was talking to the guys at my track last night. They were telling me that because our track is A blue grove and very tight, that NOT using a one way would help in the turns because of the bind that 4wd has would act as a brake. They told me that if I went to a bigger track that I would need a One way. I understand the bind that 4wd has. I drive a grand cherokee that is full time 4wd, the bind is there. I would assume it would be the same. We will see. Most of the guys at the track use the one way, but they advised me that I don't need it there. Kinda conflicting I feel, I guess i need to learn for my self. Thanks for the feed back.
Doug
Old 10-26-2006, 09:09 PM   #9
sport10's Avatar
All I can say is to run the oneway and see if it helps your times. In most instances a oneway helps a 4wd have sharper turn in and because it brakes with only the rear wheels helps to control spinout in the corners. These two traits would seem to make it ideal for a tight course especially if there are quite a few 180 degree turns.
Associated B44
Associated B6
Associated TC7.1
Old 10-27-2006, 01:24 AM   #10
Anybody else have a problem with the outdrives not staying in the one way bearing hub? I've got the springs in the outdrive, and limiters in the shocks, but it still comes out real easy and I already ruined one bearing...
pdizzy is offline   Reply With Quote
Old 10-27-2006, 08:29 AM   #11
I consider the track layout when deciding which to use. If there's a lot of braking corners use a diff. If it has smooth flowing turns use the one-way. Maybe I'll use the one-way in qualifying and go to a diff for the main so I can dive into corners harder.
Also pay attention to how your car flys and lands with a diff or a one-way. If there's a 180 right after landing and you need to get on the brakes on the back side use a diff. If its a 90 after the landing and you need to scoot out of there use a one-way.
If the track has little kicker jumps that always kick the front end down I like to have the one-way because it seems to keep the front end a little higher and it rolls away better when landing front wheels first.
As for keeping your one-way healthy make sure that the dogbone pins do not bind on the drive cup or the little ring on the drive cup. Check your drive cups often to make sure they are perfectly smooth. I burnish the slots of my drive cups so the pins slide easier.
slow is offline   Reply With Quote
Old 10-27-2006, 10:58 AM   #12
Dougg's Avatar
Thanks for the last post. My track does have 180 turns at the landing ramp on several turns. that post made a lot of sence to me.
Doug
MBX7r, MBX7R Eco, 22-4 2.0
Old 10-27-2006, 01:48 PM   #13
alb
Trader Rating: 19 (100%+)
So, What would a center one-way (on a shaft car) do differently than a front one-way?
alb is offline   Reply With Quote
Old 10-27-2006, 02:33 PM   #14
Jack Smash's Avatar
Trader Rating: 29 (100%+)
A center oneway is a little less aggressive on power than a front one-way. A front one way is basically a spool on power.
I always run a one-way of some kind on a 4whl offroader. Small tight slick track, big open high bite tracks, blue groove, tacky clay, loamy. The problem for me is I like alot of corner entry steering and you just cant get it with full time 4wd. Tires only have so much traction available to them, so if your using some traction for braking, you have less that you can use for steering.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 11-06-2006, 07:43 AM   #15
Check the Tech page and the forum on www.4wdrc.com for lots of info on various 1-ways and infor on making a Losi unit last as long as possible.
Engineering Without Fear
www.xfactoryrc.com
www.facebook.com/XFactoryRC
YoungChazz is offline   Reply With Quote
losi xxxt ball diff change to a 1/10 desert truck diff newbie2 Electric Off-Road 49 12-13-2010 08:49 PM
NTC3 Complete ATD Diff, diff nut, pivot ball socket caps Judge Joe Brown R/C Items: For Sale/Trade 2 05-09-2008 10:18 PM
[B]Fioroni Center Diff And Front Diff And Ofna Torsion Diff For Hyper 7[/B] Imdadundada7 R/C Items: For Sale/Trade 22 08-07-2006 11:11 PM
front lock diff vs gear diff rhed Nitro On-Road 4 11-29-2005 02:20 PM
XRAY T1FK04, XRC 4.0mm Chassis, One-Way, Diff, Hudy Spring Steel Diff, and MORE! BobbyDoyle R/C Items: For Sale/Trade 10 08-18-2005 04:38 PM
