help please!
help please!
allright guys i have an lrp esc for 13 turns and up
and i have a trinity cobalt original 13t motor
and when i connect them it dosent work, all the wires
and connections are right, the steering servo works but no motor power
are you 100% that the motor is ok? I have a setup with 4 "AA" NIMH's wired together in series to break motors in (when i ran brushed motors) and also test for things like this. Make sure it actually works with direct power as it might end up busting up your ESC if its shorting or hung up.
Make sure you plugged in you ESC plug into the receivers throttle channel and the polarity is correct. Also, make sure to have the drive wheels off the ground when you turn it on as it might take off. Perform the transmitter setup as described in your escs manual.
yup i checked all that,think i need a new esc?
Is this a new motor? Does the motor run under direct power? It is possible that some dirt has made one of the brushes stick and not making contact with the comm of the motor if the motor has been used before. You would need to take it apart and throughly clean the motor using motor spray.
