Old 10-24-2006, 01:04 PM   #1
RCpurplecow's Avatar
Default E-Maxx camber
Is there any way to adjust the camber on an E-Maxx. The upper arms are molded so I thought you couldn't. Are there any arms that hold turnbuckles that I can purchase to adjust camber? thanks
RCpurplecow is offline   Reply With Quote
Old 10-24-2006, 01:09 PM   #2
encore75's Avatar
Trader Rating: 26 (100%+)
Send a message via AIM to encore75
The E-Maxx has a pillowball suspension, so you can adjust camber by adjusting the pillowballs on the ends of the suspension arms (they're inside the hubs). For example, if you wanted more negative camber, screw in the upper pillowball a bit and let out the lower one a bit. Use the hex wrench that came with the kit, if you have it.
Of course, be sure you check that you're not binding or haven't let the pillowball out too much.
Tamiya TB-Evolution V & TA05-R | Kyosho Ultima SC & RB5 | Associated FT RC18T
encore75 is offline   Reply With Quote
Old 10-24-2006, 01:14 PM   #3
Default thanks
thanks
Camber? When to use and when not to use? nitrobeast Electric On-Road 14 07-15-2008 09:03 AM
Camber out / Elevated Camber ronestar Nitro On-Road 0 07-27-2006 07:24 AM
how to set my camber to zero aquito Electric On-Road 4 05-03-2006 11:00 PM
camber? peahbeez Electric Off-Road 4 06-02-2005 03:26 PM
how to set camber ? Blaze1 Rookie Zone 5 05-04-2004 06:37 AM
