Old 10-16-2006, 07:32 PM   #1
dirtracer1's Avatar
Default fuel thread
.12's to .21 engines......what do you use....and why?
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
B&T R/C - http://b-treman-rc.valp.net/btrchome.htm
dirtracer1 is offline   Reply With Quote
Old 10-16-2006, 08:49 PM   #2
Scottmisfits's Avatar
I was using Sidewinder in all of my engines. I was using the 30/10% blend. This season I switched over to the Werks fuel. The things that are said about the Werks fuel are true. It run's cooler, a tank will last longer, and it's an easy fuel to tune.
This is a fuel that I would HIGHLY reccomend.
Scottmisfits is offline   Reply With Quote
Old 10-17-2006, 06:45 AM   #3
dirtracer1's Avatar
what about o'donnell fuels?
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Old 10-17-2006, 06:57 AM   #4
Trader Rating: 14 (100%+)
I've used o'donnell for the past 5 years in my 1/8 and 1/10 trucks, great fuel. Be careful with the 30% though, the exhaust fumes will burn you eyes, throat, and mouth!
I'm going to run sidewinder in my 1/8 and will continue to run OD 20% in my truck.
o.s. power is offline   Reply With Quote
Old 10-17-2006, 12:26 PM   #5
WheelNut's Avatar
Send a message via MSN to WheelNut
I run HPI 30% in my .21's. Its not expensive, its easy to get where I live and it run great. Plus unlike Werks if you get some on your clothes it does stain them!
•Brad Comis
WheelNut is offline   Reply With Quote
Old 10-17-2006, 02:33 PM   #6
22Racer's Avatar
Trader Rating: 67 (100%+)
We ran White Lightning for a year, we recently switched to Byrons. We did have to richen the motors because the Byrons has more oil. (11%) So the White Lightning does get better mileage but I thought it might wear parts a little more.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail [email protected] Rex Welch
22Racer is offline   Reply With Quote
Old 10-17-2006, 02:36 PM   #7
Aaron Waldron's Avatar
I've run Trinity fuel for years. The Platinum stuff has less oil than some of the other fuels, but it helps keep temperatures down, more run time, and more power. If you're confident in your tuning abilities there's no reason to run a fuel with lots of oil. I've always gotten good engine and bearing life with Platinum fuel, even when running my engines hard at bigger races.
20% in .12's (no reason for more power!) and 30% in everything else.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 10-17-2006, 03:39 PM   #8
nobike's Avatar
Trader Rating: 147 (100%+)
Same thing, I tried sidewinder, o'donnell, and a couple others, werks HIGHLY reccomend by me too!!!
nobike is offline   Reply With Quote
Old 10-17-2006, 04:55 PM   #9
dirtracer1's Avatar
does anyone have any feedback on Maxy's fuel?
btw.....good stuff all, keep it coming.
Losi 22
Losi 810-e
Losi SCTE
Losi XXX-MF2/CRC SC
Old 10-17-2006, 06:07 PM   #10
Davidka's Avatar
Trader Rating: 77 (100%+)
Byron's 30% race blend for me. Very consistent and never a need for after run oil. My engines were surgically clean after a season on this stuff.
Old 10-17-2006, 07:44 PM   #11
rdeppen's Avatar
dirtracer I ran Maxy's fuel for years and will probably run it again, good stuff and Maxy is salt of the earth on a personal level. I have never had an engine or internal bearing failure using Maxy's Fuel. I've recently gone back to Odonell if for no other reason it's ALWAYS consistent and I can get it at a LHS right down the street.
When I start hitting up allot more races next season I'll most likely go back to Maxy's to support the local guy
If you can find it in your area Jax fuel is also very good and they are good people as well.
rdeppen is offline   Reply With Quote
Old 10-17-2006, 08:59 PM   #12
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to W.E.D.Jim
dirtracer, I have raced alot of fuels over the years i've been racing. ODonnel, Trinity, Traxxas, Byrons, Maxy's, sidewinder and more.
In all honesty, I have not found any that are magical and give you 2 minutes extra run time, 4 seasons out of an engine, or no visible wear after 8 gallons, etc. They all use a blend of alcohol, Nitro and oil blends in castor or synthetic or both, of varying percentages. If they have the same percentages, the results will be the same, except in the case of inferior lubricant or corrosion packages in some products.
99 % of the problems are created by the tuner, or lack of one, not the fuel.
I have run Maxy's for a while now, because it is a good value, with top materials used in it, no short cuts. Also because Maxy is the only manufacturer that attends races and will actually get out a screwdriver and help someone who needs it when he spots them struggling!
Maxy is a stand up guy who represents our sport well!
But, if his fuel wasn't just as good as others, I would leave him hanging, LOL!
....Jim
www.wedjim.com ...Reopening soon. I'm still painting, just not with 40+ bodies waiting. :)
www.prolineracing.com
www.HarleyDavidson.com
"Nothing but the best!"
W.E.D.Jim is offline   Reply With Quote
Old 10-17-2006, 09:06 PM   #13
Trader Rating: 39 (100%+)
O'Donnell's 30% because its always in stock and easy to get.
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 10-17-2006, 09:12 PM   #14
brian cox's Avatar
Trader Rating: 58 (100%+)
rocket science --- cause i like texas
Team Orion---Bradley Fine Line Design---AKA
brian cox is offline   Reply With Quote
Old 10-17-2006, 10:51 PM   #15
Well there are only two brands where i live.
At first i was running Tornado 16% and it seemed normal on my RB C5BB .21, bet when i tried out the O'Donel 16% fueal it was way better, the temp increased to normal (i was always too cold with tornado) and the bog'ing after refueling or some idle has gone away.
So from my experience i made a conclusion that
O'Donel is better than Tornado.
Taurius is offline   Reply With Quote
Maxy's Fuel and Maxy's Mod Engines (Official Thread) Tabushi Offroad Nitro Engine Forum 97 01-07-2014 09:43 PM
1/8th scale Fuel Mileage Thread Scootersisters Nitro Off-Road 8 10-07-2007 07:27 PM
Maxy's Pro Racing Fuel thread Alex Lopez Nitro On-Road 3 03-05-2007 03:44 PM
<NEW> MONSTER TRUCK FUEL FROM MAXY'S PRO RACING FUEL !!!! <Maxy's> Nelson Racing Forum 0 11-08-2005 10:13 AM
Does O'Donnell fuel make a huge accel. gain on HPI fuel Smoke21 Nitro On-Road 3 05-03-2004 05:44 PM
