Old 10-04-2006, 08:21 AM   #1
bikedoctor's Avatar
Default Can the RC10T2 still be cometative??
I'm thinking about bringing it back to life. Where do I get A-arms and spare parts? Tower???
kevin
bikedoctor is offline   Reply With Quote
Old 10-04-2006, 09:53 AM   #2
AndyMoore's Avatar
Trader Rating: 54 (100%+)
Send a message via AIM to AndyMoore
Of course it can be, some new tires and updated electronics make all the difference. I watched Jason Ruona win mod truck at a Florida State Series event with an RC10T
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 10-04-2006, 10:49 AM   #3
Its the magician not the wand.
Given that todays transmisions and cars are a lot more durable. Parts for a T2 will be hard to find and pretty limited. That more than anything will hurt you at the track.
Syxxstring is offline   Reply With Quote
Old 10-04-2006, 01:55 PM   #4
bikedoctor's Avatar
The magician not the wand........ I like that.
Old 10-04-2006, 02:39 PM   #5
seth556's Avatar
Trader Rating: 42 (100%+)
The wand's just for show. The magician does the trick...
But the rc10t2 can defently be competive. Make sure all the bearings are running good. Then update the electronics and battery. Get some good tires and go have fun.
seth556 is offline   Reply With Quote
Old 10-04-2006, 03:35 PM   #6
WheelNut's Avatar
Send a message via MSN to WheelNut
The T2 uses the same suspension as the RC10GT right? So a lot of the suspension parts should be easy to get. I think AE sells most all of their old parts still, you'll just have to wait a while for them most likely.
•Brad Comis
WheelNut is offline   Reply With Quote
Old 10-04-2006, 04:50 PM   #7
bikedoctor's Avatar
You guys are absolutly correct. I called associated and their tech is not nearly helpful as you yo-yos. I appreciate you.
I have been checking with Tower and so far I can still get the steering knuckles, a-arms, and shock towers. Anything else I should grab up before the stock is all gone? I cant remember what broke the most on that sucker.
Kevin "new old stock"
Old 10-04-2006, 06:09 PM   #8
seth556's Avatar
A lot of the stuff is on tower but isn't listed under rc10t2. You just have to type in what the part is.
Old 10-04-2006, 06:29 PM   #9
dallasv8's Avatar
Talking T2 rock
i got a new body, body mounts, rpm arms,lightweight cvd's ,diff set etc from tower for my T2.
if you dont end up racing it ill take it off your hands
RC10B4
FT RC10T4
Proline Pro 2 SCT
Piss on holden
dallasv8 is offline   Reply With Quote
Old 10-05-2006, 07:41 AM   #10
bikedoctor's Avatar
Dallas,
Do you race your T2??
Old 10-05-2006, 09:11 AM   #11
dallasv8's Avatar
Talking sure do
yea mate.in townsville in australia.i also race a B4.
i really like the T2.with the rpm arms it is tough as and i like the squarer body.i hate the bodys on the new trucks.
main thing i have to work on is is getting more front end grip.i think after i replace the slipper pads and set the slipper properly that might help.(it likes to wheely on high grip which doesnt help coming out of corners)
RC10B4
FT RC10T4
Proline Pro 2 SCT
Piss on holden
Old 10-05-2006, 11:10 AM   #12
bikedoctor's Avatar
you said mate
Old 10-05-2006, 01:34 PM   #13
Driver1's Avatar
Send a message via AIM to Driver1
I still believe the T2 is the fastest, most driveable truck ever produced. I miss mine to this day. Especially on large outdoor tracks that get a little rough.
A few tips to get more front grip. Make sure your dif. is tight. I think back then the recommended setting was 1/4 turn out, but you can tighten it to maybe 1/8 or somewhere in between. Then tune with your slipper.
Next the rear axle carrier placement is critical. Move it up as far as you dare. I believe this truck was pre-moveable hubs, and we had to Dremel the front-inside of the a-arm. I don't remember for sure, and maybe they introduced this with update parts. Even still move them up more if the arms are not compromised.
Then the anti-squat on this truck was very useful. Take some out. We used the thin outdrive shims to accomplish this. Stack some up under the rear suspension mount to flatten the arm a little. We used quite a few, but work up to it.
Keep in mind that ride height will become critical. Keep the axles level, and if it wants to come around on you raise it a little. I used to draw an imaginary line from hub to hub, and kept the arms and the axles equally distant from this line. Then set your front ride height by referencing the rear, the chassis needs to be perfectly level. It should be about arms level, but it's more important to keep the chassis on a good plane.
Next move to the front. Make sure the bump-steer is perfectly neutral. I'm pretty sure AE made a spacer specifically for this. This is a bench test as you can compress and rebound the arm and observe the reaction of the stub axle. Use that ackerman. The T2 allowed adjustment of this rate, contrary to modern cars, much to my disappointment. Make it a little more aggressive by moving the steering arms closer with the little tie-rod. Don't overdo it, but it can be educational to move them a lot and then try driving it.
Put on the 20degree castor blocks now. The truck will easily wash out on exit if you don't. If the front is too aggressive on entry take a little of that ackerman out, and make sure you have NO toe-out. Stand the front wheels up a little and go with a little firmer foam and harder tire.
As always, 80% of off-road is the tires, and I don't know how any of this will respond to modern compounds.
Know how to build AE shocks, and keep the truck neutral. When dropped from about 6in. it should compress and rebound equally and neutrally. No slap and no hop, and no difference in rate front to rear.
Now you will tune with your str d/r, esc and slipper. This was cool. It reminded me that you used to have to know how to build a car to be fast.
Lastly, if anybody has a new-in-box T2, I would love to purchase it. I can be reached at [email protected]
Driver1 is offline   Reply With Quote
Old 10-07-2006, 09:48 AM   #14
bikedoctor's Avatar
Great info guys. 10x better than anyother source Ive found.
WTB: RC10T2 GAMMACRUSH R/C Items: For Sale/Trade 3 02-02-2008 04:15 AM
What bodies will fit RC10T2? SuNnY_D Electric Off-Road 3 12-28-2006 01:29 PM
WTB: RC10T2 GAMMACRUSH Other Items: For Sale/Trade or Wanted to Buy 2 10-05-2006 06:12 PM
WTB: RC10T2 Ed Pasoquen R/C Items: Wanted to Buy 5 06-17-2006 05:37 PM
Need 3/16 CVD's for RC10T2 omalley R/C Items: Wanted to Buy 0 08-20-2003 01:10 PM
