Old 10-01-2006, 04:41 PM   #1
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Default Novak GTB ESC cooling fan
Hi , I received my first brushles yesterday and ran it today . I noticed that a blade on the cooling fan was missing already and sure there will be more falling off . Are there any better fans to use other than the stock one ? I thought I read on a forum that they were using a different fan , but can`t remember which forum I seen it in . Any help will be greatly appreciated .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 10-01-2006, 05:01 PM   #2
sepirts's Avatar
I've used the stock novak fan, no problem. I've run my GTB without fan for everything except really hot summer days and 4wd (TC or buggy). buggy and truck just don't seem to get the gtb hot enough.
sepirts is offline   Reply With Quote
Old 10-01-2006, 06:07 PM   #3
Trader Rating: 28 (100%+)
The fan on my gtb works fine and has never lost a blade. I take it off now and then to clean it off. Was it missing from when it was brand new? If so I'd call novak and maybe they will send you a new one.
jbrow1 is offline   Reply With Quote
Old 10-01-2006, 06:58 PM   #4
scott_g's Avatar
Send a message via MSN to scott_g Send a message via Skype™ to scott_g
There is a Much More fan that is a straight bolt on replacement and plugs directly into the fan point on the GTB. Stronger, and pushes a higher volume of air. It's a little thicker, but a better option than the standard fan.
It's the 30mm fan - part # MR-30FAN. Check here: http://teammuchmore.com/product_info...products_id=76
schumacher, speedpassion and more plus race blog at www.actionrc.com.au
twittering @ scottyg_rc
scott_g is offline   Reply With Quote
Old 10-01-2006, 07:07 PM   #5
Briguy's Avatar
Thanks , but who sells them ? I checked on their dealers listed and none of them have it .
Royal R/C & Hobby
Old 10-02-2006, 09:01 AM   #6
Rysuleod's Avatar
If you are desperate you can call computer stores and see if they carry small fans like chipset cooling fans. My buddy had some luck finding a thin fan that he bolted above his Novak SS+ for cooling. I've seen those Novak cooling fans break after 1 run on at least two occassions. To be fair to Novak it's not obvious if the plastic is too brittle or if the people using them just crashed too hard.
Rysuleod is offline   Reply With Quote
Old 10-02-2006, 09:05 AM   #7
RAZ49's Avatar
Radio shack sells a small fan the fits perfectly and works great, they go for $13.00. I've been using one on my novak esc for a while and it does help.
RAZ49 is offline   Reply With Quote
Old 10-02-2006, 05:06 PM   #8
B4Bandit's Avatar
I lost heaps of blades on my stock GTB fans. You've got to be careful that all tour wires are clear and that your fingers stay away!!!
B4Bandit is offline   Reply With Quote
Old 10-03-2006, 07:10 AM   #9
scott_g's Avatar
Here it is at Speedtech - $11.99. Currently showing out of stock but I'm sure they'll order it in for you.
http://www.speedtechrc.com/store/ebp...id=129&id=5218
Old 10-03-2006, 07:16 AM   #10
scott_g's Avatar
Or showing in stock at Nexus Racing:$9.99
http://nexusracing.net/product_info....0a423081d31aaa
Cooling fan Set-ups TimPotter Electric On-Road 19 05-09-2007 05:21 AM
Novak cooling fan how do I wire it? Philip Henzog Electric On-Road 3 10-24-2006 12:30 AM
2 stock 2.5 cooling heads, 8 big bore shocks And a novak dually esc t to the maxx2 R/C Items: For Sale/Trade 2 06-09-2005 11:23 PM
Can I run with a cooling fan Franky Australian Racing 5 07-17-2003 06:40 PM
Cooling Japser Nitro On-Road 3 03-26-2002 08:38 PM
