Mamba Max, Novak or Neo/Star? >
Old 09-27-2006, 05:37 PM
Pierre-Olivier's Avatar
Default Mamba Max, Novak or Neo/Star?
What take for my AWD 1/10 buggy?
I would like to have motor like 10-11 turns MAX!!!
Not to big track but we run mod.
P-o
Pierre-Olivier is offline
Old 09-27-2006, 05:47 PM
im going to say the Mamba maxx with the 5700 motor.
Matt
mat3833 is offline
Old 09-27-2006, 07:11 PM
Im thinking that me too...
Old 09-27-2006, 08:04 PM
Trader Rating: 54 (100%+)
For a novak probably a 6.5 or 7.5 would be good. I run a 5.5 in my ZX-5 and it is stupid fast.
jsmax is offline
Old 09-27-2006, 10:03 PM
cfwdude's Avatar
I've been running the Mamba 7700 in my Bj4WE, just put in a Novak 4.5 today to test it out.
Both are fast, but there are subtle differences, which can be somewhat customized through ESc and trans programming.
with both systems set at defaults, no expo on throttle
Novak is punchier off the line. Mamba kicks in a little later. Mamba has a higher top speed. Also had to cut out a little of the chassis to fit the Mamba, since it's can is a little longer than the Novak.
The Mamba will notice if you roll backwards (like if you spin out around a hairpin), and pause until the car stops before letting the throttle kick in.
the Novak goes when you tell it. Not a big deal, but you have to be aware of it. (hello sensorless)
I think the best scenario is the Mamba ESC, and any brushless motor. The programmability of it lets you set it however you want.
the 5700 will be probably be fast enough for you, or the 6.5.
personally, I like having all the power of the faster systems, I just learn to use the first 3/4 of the throttle. Use the last 1/4 only when needed.
cfwdude is offline
