Old 10-07-2006, 10:29 AM   #31
Trader Rating: 39 (100%+)
That is the pinch bolt that secures your carb to the crank case.
Chuck
www.ridgewaybodies.com
https://www.facebook.com/ridgewaybodiesRC/?ref=hl
ridgewaybodies is offline   Reply With Quote
Old 10-07-2006, 11:06 AM   #32
captain america's Avatar
So it isn't some sort of mid-speed needle then?
Sorry, just want to double-check
captain america is offline   Reply With Quote
Old 10-07-2006, 11:18 AM   #33
No, not a needle at all. Your carb just has two needles, a HS and LS needle.
Chuck
Old 10-07-2006, 06:47 PM   #34
Trader Rating: 28 (100%+)
Originally Posted by captain america
In so much as this is a thread concerning the P5X, I have a couple of quick questions:what the heck is the screw circled in red? I figured I'd ask before doing anything to it, as there is no mention of it in the documentation that came with my mill.
Second, how do I go about removing the carb assembly? It seems to be impossibly-hard to remove, and I'd rather not force it in case I'm doing something wrong
The P5 is a two needle carb. Just a high speed and low speed, and also the idle screw but that isn't a needle. What you have circled is the bolt that keeps your carburator locked to the engine block. If you loosen that bolt you will be able to remove the carb quite easily. Once you take it off you'll see exactly how that bolt (screw) retains the carb.
jbrow1 is offline   Reply With Quote
Old 10-07-2006, 07:00 PM   #35
Originally Posted by B0nzz
Although, I would like some more info on the MSN if you have it.
From what I gathered it actually changes the barrel to go from the LSN to the HSN at a different time. Does this mean after I get it to run, sounding good on the top, and running hot, I can adjust the MSN to kick in the HSN later and run the bottom a little fat for cooling? What direction does the MSN need to go say for a longer duration on the LSN
Ca
Again the middle needle and the low speed needle have to be adjusted as a pair if you are going to use it. Personally I wouldn't recommend it myself as just turning two needles is difficult enough to keep track of. Your low speed needle setting also works hand in hand with your idle setting. I would say no you can't really change the middle needle (seat) and run the low speed fat for cooling. Your low end is either fat, lean, or good. If you run a fat low end, it's still gonna be fat on the low no matter where your power band kicks in. If you bash around and drive alot around mid to full throttle your cooling will be mostly done with the high speed needle regardless of where the low or other needles are set. I see what you are getting at but I don't think it'll really work.
Old 10-07-2006, 10:19 PM   #36
B0nzz's Avatar
Thanks JB
I guess a little knowledge is a dangerious thing...
ca
B0nzz is offline   Reply With Quote
Old 12-13-2006, 01:17 PM   #37
Hrdluck13's Avatar
Trader Rating: 8 (90%+)
Can I use the tip of my 1.5mm hex wrench as well??
Hrdluck13 is offline   Reply With Quote
set up and tuning question Blisster Rookie Zone 2 07-31-2007 04:38 AM
SH .28 Tuning question Nickmind Monster Trucks 3 04-13-2006 09:47 AM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 03:01 AM
Question about tuning.... UNITED_RC Nitro On-Road 3 01-19-2004 07:27 PM
Tuning question TRF-Powered Electric On-Road 4 04-08-2002 02:57 PM
