Help with Clutch Shim
No, you need it to spin free while being screwed on tight....What's happening is the shaft is not extending all the way through the end of the clutch bell and/or it's bearing... you need to add shims to the screw itself, they are tiny shims that fit right down inside the bearing and you need to add enough just to get the head of the screw off the bearing...and you should have just a little bit of play then the bell will spin freely....
I hope this makes sence to you! ....I just rolled out of bed and am not sure if all that is worded correctly !! Let us know if you get it fixed
Yeah, there are lots of tricks to this, but you need the bell to be vey "free" to spin.
Originally Posted by Inferno
I now have it going with shims on but I can move the clutch bell slighty up and down. Is that bad?
Cheers
Cheers
But just a little bit of play.
hope this helps
