Old 09-26-2006, 11:16 AM   #16
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
Oh sorry about that, I wasnt clear LOL
I mean like what speed mode can it be used with, I have a Helio which has like "normal" mode and a "High Speed" mode behind the module. Im just wondering which it uses.
Sorry for the confusion.
K_King is offline   Reply With Quote
Old 09-26-2006, 11:54 AM   #17
Trader Rating: 15 (100%+)
K_King:
No problem. I don't have a Helios but I would assume that the HRS mode is for Digital servos and the regular mode for analog servos.
7.5man is offline   Reply With Quote
Old 09-26-2006, 11:57 AM   #18
K_King's Avatar
Originally Posted by 7.5man
K_King:
Yes you are correct.
Old 09-26-2006, 01:14 PM   #19
K_King:
So is that the info you needed? If so just run the switch according to the servos you have installed in the vehicle.
Old 09-26-2006, 02:04 PM   #20
K_King's Avatar
Well Im guessing I can run the High Speed mode on the Spektrum fine?
Old 09-26-2006, 03:15 PM   #21
K_King:
That I wouldn't know. You can try it but if it doesn't work then set the switch to what type of servo you have installed. Hopefully you don't have 1 analog and 1 digital servo....That could be very interesting. I don't know if the Spektrum covers each servo individually or not for settings.
In my Sensor settings, I can make either the steering or throttle servo setting analog or digital to whatever the servo is and the radio goes from there.
Goodluck....
Old 09-26-2006, 03:34 PM   #22
K_King's Avatar
Well I will definately get a digital if I can use the high speed mode with the Spektrum.
Old 09-26-2006, 03:35 PM   #23
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Briguy:
You are pretty funny fellow. Heres something for you to chew on:
http://www.horizonhobby.com/Products...rodID=KOP80066
If you look closely at the Helios it says FM at the top of the page. It can be switched to HRS which increases speed with a digital servo. The FM mode by trait is analog.
Even though when you use your Spektrum 2.4 Gig module and reciever which is digital by itself the analog Helios transmitter only transmitts in a analog FM signal to the Spektrum digital module.This is not digital at all....
Hence you see racers with the Nomadio system call the Spektrum system "Da Slow Mode" because it is not a 100% digital radio and 100% digital module/reciever working as one unit.
Now whether you like the Sensor or not I could care less but I don't like being told that I spread false info. If I did not know for sure I would have never said that the Helios is not a digital radio but just a FM radio. I have been in this hobby for many, many years and misleading people is not my bag.
I'll take your apology now.....
thanks....
Think what you want . Ko says it is along with what the manual says . SAYS RIGHT ON THE MANUAL COVER . Anyway , you never had a Helios , but you know it all . As a matter of fact I just got a response back from Robert Morris @ KO explaining the high and normal mode along with it being digitial .
PM me with your email address and I will gladly forward it to you .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
receivers and servos al spina R/C Items: For Sale/Trade 2 04-13-2008 10:04 AM
Receivers, servos... Crashhole R/C Items: For Sale/Trade 2 02-17-2008 10:56 PM
many hi-end servos, receivers, and speedos billjacobs R/C Items: For Sale/Trade 15 04-06-2006 12:06 PM
FS: Two JR RS-300 synth receivers and two servos Trips R/C Items: For Sale/Trade 8 02-13-2006 09:47 AM
Servos and Receivers RJ1 R/C Items: For Sale/Trade 7 09-25-2005 06:27 PM
